Valve size for Magnuson 2300?
Old Oct 27, 2019 | 02:56 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Valve size for Magnuson 2300?
Would stock LS1/2 valves or oversized valves be better for use with a Magnuson 2300?
I hope to get heads/cam next year, but I want to select heads that will work best with the Maggie. So... 2", 2.04", or 2.08" intake valves?
Old Oct 28, 2019 | 05:07 AM
007FJ's Avatar
Exhaust side is where you need help. Any ls head is good with the blower on the intake side. Just get a cam for the application if you have the money to spare. On a budget the ls9 cam is damn good for the money
Old Oct 28, 2019 | 05:09 AM
007FJ's Avatar
Clamping power is the only real issue if it’s a high power set up. If it’s a square port then if you find some Lsa or ls9 heads that’s a good thing. Chances are though any head with ls9 gaskets on trued surfaces will suffice
