Single downpipe into dual pipe advice please
Old Nov 8, 2019 | 11:34 AM
Mark30's Avatar
Default Single downpipe into dual pipe advice please
Would like to have some advice on the limits of a single 3.5 downpipe into dual 2.5 exhaust. I don't want to have a loudvalve or dump pipe and am willing to accept the limitations of that. Looking at using a vs racing 7875 turbo with a lq4. Nothing at all thats exotic in the setup. I would consider using a dual 3" but I would rather use what I have now if it will be ok.
Thank you
Old Nov 8, 2019 | 11:50 AM
yenkomike's Avatar
most 78/75 turbo's ive seen are 3" downpipe. dual 2.5 will not hurt it any if at all. I ran dual 3" from my 4" downpipe and it made no difference except carrying the extra weight.
Old Nov 8, 2019 | 01:42 PM
forcd ind's Avatar
If your using mufflers, I would prob run the straight thru, like Dynomax or something.
Old Nov 8, 2019 | 01:48 PM
Kfxguy's Avatar
That is exactly how i had it on my car, 3.5" down pipe to single 3" to (2) 2.5" pipes. worked fine.
Old Nov 8, 2019 | 05:13 PM
Mark30's Avatar
Thank you for your help. I currently have a 2.5" dynatech system which has the straight through type mufflers.
Old Nov 8, 2019 | 05:42 PM
Kfxguy's Avatar
It’ll work perfectly.
Old Nov 9, 2019 | 01:22 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Dual 2.5" is slightly more area than single 3.5", so why would there be any problem?
