Gen 4 5.3 flat top pistons and boost ?’s
Thanks
Richard
If the engine is already apart, gap the piston rings and new bearings if you feel inclined or reuse the old ones if they look good.
Cam will depend on the turbo you select and budget.
Fuel type would determine which head I'd run, E85 and 243's or pump gas and 317's.
This is my personal preference and others will feel differently and you should certainly take their info into consideration as well as some guys on here have built way more of these engines than me.
Lotta guys run 243 heads on the 5.3 with boost, I myself have a set of CNC ported 317's I'll be using with flat tops should bring the static compression ratio in right around 9.5:1.
Either head will work well but the 243 will have higher compression for faster lighting but also smaller tuning error window.
If you're having a professional tuner do the work then you'd be fine.
I'm only speaking from the realm that all pump gas is not created equal and if you drive your car everywhere like I do then i like to be a little conservative to compensate for crappy gas.
Its probably pretty negligible but I like to air on the side of caution.
I'd keep an eye out on this forum for a used cam as well, something like a BMR/LJMS Stage 2 Turbo cam (they're the same) or a Tick 5.3 Stage 2 Turbo cam.
Either of these will work very well with a range of turbos from 7875 up to the larger S475 turbos, the cam will really determine much power the engine will make efficiently.
You've gotta be quick in picking them up because they go fast.
Thanks
Richard
The 5.3 I'm doing had 164,000 miles on it and still had cross hatches and good ring tension so my builder said I can definitely re use them which I will.
A lot plays into turbo sizing, intended use, power goal, space, transmission type, etc.
I think an S475 fits many applications from auto to manual trans and if you find a cheap used one can be a great place to start and make decent power.
5.3 w/ 317 heads, BTR or LJMS Stage 2 turbo cam, S475 outta be a safe 600whp car on pump gas and with used parts cheap too.
it down and replace rings, bearings, and yes, cam bearings. We are talking about $200 in
parts. I am lazy, pulling an engine after it is in and running isnt high on my list, lol. Even if just
pulled it down for inspection, you need to replace some gaskets, bolts, so I dont ad them in
to the costs. Your results may very.
If bearings look good, I wouldn't mess with them unless you have a bore gauge and mic to know where the current bearing tolerances are at. It seems many guys end up with bearing failures due to tight tolerances for the HP their running (crank flex causing failures). Factory rings and bearings seem to perform well so be cautious about replacing them with a lesser quality and poor results.
Didn't hurt the block luckily so perhaps the op had a similar situation.
Been considering one myself but there as many to choose from as there are horror stories about issues.
