Turbo water cooling
Old Jan 4, 2020 | 08:16 PM
Theduck's Avatar
Default Turbo water cooling
I'm doing twin garretts . it's not a drag motor . so I want to take advantage of the water cooling ports on the turbo center section . who is running a cooling system INDEPENDENT of the engine cooling system ? I need some ideas . as far as the pump and cooler .
Old Jan 5, 2020 | 10:07 AM
Project GatTagO's Avatar
Why would you run an independent cooling system instead of using the engine cooling system?
Andrew
Old Jan 5, 2020 | 09:32 PM
Theduck's Avatar
Cooler temps , it will be run through a separate cooler with a thermostat controlled fan . such as a large trans cooler
Old Jan 5, 2020 | 10:56 PM
jordoza's Avatar
Honestly garret water cooled turbos are meant to be run at engine temp. I see what your trying to do but i dont think it will be worth it in the end. Save the time and money your gonna spend on this and K.I.S.S (keep it simple stupid) is my best advice. Believe me im one to over engineer a fly swat but it rarely is better then the original product.
Old Jan 6, 2020 | 12:30 AM
Theduck's Avatar
sometimes I forget to keep it simple.
Old Jan 6, 2020 | 12:54 PM
TastyBacon's Avatar
I installed water-cooled Garrett twins in 2018 and went over all my options to plumb them. I also came to the conclusion to just keep it simple--I plumbed the two turbos in series, teed off the heater core lines. Heater core feed -> tee to passenger turbo -> hose from passenger turbo to driver turbo -> hose from driver turbo to tee in heater core return. I used 3/8" hard lines at the turbos into 1/2" rubber hoses once they were far enough away from exhaust heat. Probably could have just used 3/8" all the way. They don't really need much flow, they just need to be connected to the cooling system. Clock the center sections correctly and convection will take care of the rest; the magic happens after you shut the car off anyway. 10k street miles later, no complaints.
Old Jan 16, 2020 | 12:48 PM
rotary1307cc's Avatar
This is being waaay overthought
Old Jan 16, 2020 | 01:03 PM
AwesomeAuto's Avatar
People actually cool non-OEM turbos?
 Michael S. Palmer
Old Jan 16, 2020 | 03:01 PM
truckdoug's Avatar
yeah like pikes peak cars and **** have watercooled turbas.
but on your average slidey boi thats in boost a **** ton longer than a drag application, oil cooling is plenty. but like any dorifto you otter have an oil cooler and a monster oil capacity or a dry sump
