Turbo size ideas
Larger engines are pushing a lot more exhaust volume for the amount of boost they are making, meaning a high backpressure ratio. It makes it hard to make power.
Turbos being more efficient usually at higher pressure ratios doesn't help with their power production at 10 PSI either.
Just because a T4 can make 1200+ HP at the wheels on a 4.8 doesn't mean it can even make 1000 at the wheels on a 438.
You're going to need a T6, or twin T4s.
https://ls1tech.com/forums/market/1931584
https://turbo4less.com/product/vsr-9...illet-t6-1-24/
