Looking To Build A Forged 347 On A Budget
Old Jan 13, 2020 | 08:09 PM
waggz's Avatar
Default Looking To Build A Forged 347 On A Budget
I'm kicking around an engine build for my Dragzine project car since the stock LS1 seems to be terminally ill after some exploratory surgery.
The project idea is to do a budget based 347 with some forged parts that will run on E-85 with a "goal" of at least 700 horsepower. After doing some research it looks like there have been similar combos build using a stock crank. I want to go with a D1 from ProCharger and stick some good pistons and rods in the block.
In the spirit of keeping this as a budget build should I stick with my stock LS1 heads and LS6 intake? It will need a new boost-friendly cam since the current nitrous cam won't work.
Any advice from those who have gone down the budget 347 route before?
Old Jan 13, 2020 | 11:11 PM
69gto96z's Avatar
Stock crank, compstar rods, wiseco pistons, all arp hardware, stock ls6 block here. Ported 243s with LS6 intake. Car see’s 20 psi from a YSi and loves it.
Old Jan 14, 2020 | 06:28 AM
waggz's Avatar
Originally Posted by 69gto96z
Stock crank, compstar rods, wiseco pistons, all arp hardware, stock ls6 block here. Ported 243s with LS6 intake. Car see’s 20 psi and loves it
That's kind of the route I want to go. The goal of this build for the magazine is to show people you can actually build a pretty nasty combo on a reasonable budget.
Old Jan 14, 2020 | 07:54 AM
ddnspider's Avatar
What's the budget?
Old Jan 14, 2020 | 12:34 PM
waggz's Avatar
What's the budget?
Since I'll be using the stock crank I would like to keep the other hard parts to under $3,000 or $4,0000 I guess. I'll be assembling the engine myself at home.
Old Jan 14, 2020 | 02:48 PM
ddnspider's Avatar
Shoot, thats plenty to build it. Look at the @Summitracing forged pistons and rods combo. ARP head studs, MLS gaskets. Stage 1/2 cam, stock heads and LS6 intake. Pulley down and go.
Old Jan 15, 2020 | 10:13 AM
69gto96z's Avatar
You could throw in a forged crank with that kind of budget if you wanted to.
Old Jan 16, 2020 | 07:07 AM
Summitracing's Avatar
LS1Tech Sponsor
Our Summit Pro LS pistons and rods are up to the task. The pistons are modern 2618 forgings designed for boost and nitrous. They have thick ring lands for durability. The rods are top-notch 4340 H-beams precision-honed in the USA to +/- .0001". The rods come out of the box with ARP 2000 7/16 rod bolts with 200,000 psi tensile strength. Those are typically an upgrade option for other rod manufacturers. Our piston and rod kits come with a premium ring pack. They include steel top rings designed for boost and nitrous. They include Napier-hook second rings for maximum strength and oil control.
We would go with dished pistons for boost. We have a .005" over 7cc dished piston kit part number SUM-PR36L9037. These would put you around 9.5:1. This combo is good for 1000 whp out of the box.
You could also take a look at our Pro LS camshafts. We would look at the stage 1 or 2 in the automotive cams.
__________________
800-230-3030
www.SummitRacing.com
Old Jan 19, 2020 | 01:24 PM
red fury's Avatar
Using my 01 stock block and balanced stock crank with Compstar H beam rods, Diamond flat top pistons with heavy duty wrist pins. CR is 10.3 running E85. 3 years and going
Old Jan 22, 2020 | 07:26 AM
jayyyw's Avatar
My engine is almost done being assembled. Stock block 5.3L, stock crank, Callies Compstar rods, Wiseco pistons, upgraded wrist pins, 1/2" head studs, ARP main bolts. Pretty sure the parts came in well under $4000
Old Feb 5, 2020 | 07:48 PM
waggz's Avatar
This is VERY tempting since I might be going turbo now and still using a stock crank...
Old Feb 6, 2020 | 11:34 AM
LS1Tech Sponsor
Sounds good. Let us know if you have any further questions.
__________________
800-230-3030
Old Feb 15, 2020 | 09:17 AM
Jwooky's Avatar
Are forged pistons and rods mandatory to put big boost ~20+ through a LS1?
Im currently ~12lbs with mine SBE but considering more.
Seems the ring lands are the limiting factor. Not sure what the gen 3 rods are good for.
Old Feb 15, 2020 | 09:29 AM
ddnspider's Avatar
5.7 or 5.3? What size turbo? Pump or e85? All that matters to give an answer.
Old Feb 15, 2020 | 02:48 PM
Jwooky's Avatar
Aren’t all LS1 5.7?
twin 70’s. Wouldn’t the boost be the value that matters, not the Turbos?
pump gas.
Old Feb 15, 2020 | 03:12 PM
ddnspider's Avatar
Originally Posted by Jwooky
Aren’t all LS1 5.7?
pump gas.
Theres other people posting 5.3s in here and you can build an iron block 5.7 from a bored 5.3 too. Boost is irrelevent without knowing what size turbo. 20 psi from a 60-1 is not the same as 20 psi fr a T88. Yes you'll need forged pistons and rods and even then I wouldn't suggest running that much boost on an alum 5.7 with pump gas only and twin T70s.
Old Feb 16, 2020 | 09:02 AM
Jwooky's Avatar
Due to the thinner cylinder walls on the 5.7?
Do we understand the limits?
Old Feb 16, 2020 | 10:47 AM
ddnspider's Avatar
All depends how long you want it to last. Plenty of hero pulls out there. Iron blocks are stronger no question. Gen 4 rods are beefier than gen 3 stuff, but ls1 pistons are just weak in stock form. Typically they lift a ring land and the rings butt. Most suggest staying south of 600whp for stock pistons. Even forged people get nervous over 800-900whp or so on a 5.7.
