LS7 lifters
Old Jan 18, 2020 | 04:24 PM
3 window's Avatar
Default LS7 lifters
Moved here from the Internal engine forums.
How high have you guys run seat and open pressures on an LS7 lifter successfully? And at what RPMs? Looking at a set of BTR duals and a 7k shift point. Cam is mild .570 lift
Old Jan 18, 2020 | 04:33 PM
ddnspider's Avatar
Ls7s here with BTR 660 platinums. Have shifted at 7100. 595/586 lift. No issues so far.
Old Jan 18, 2020 | 04:34 PM
Dragframe's Avatar
Never built anything I really worried about that with. I’m whipping my truck to 7200 with a cam about that size with ls6 springs on stock lifters and pushrods.
My car has a bigger cam (), to about 7k, with btr duals on stock 150k mile lifters. It’s doesn’t have much time on it though (I need to update my build thread).
havent had a lifter failure in 15 years. But then again I haven’t blown up the 60e in my truck. So I have pretty good luck with stuff that shouldn’t survive what I do with it
Old Jan 19, 2020 | 09:14 AM
truckdoug's Avatar
i've had good luck with the white-box delphi lifters
130lbs seated, 370lbs on the nose
.600 lift going to about 7k
Old Jan 19, 2020 | 02:38 PM
ls3fox's Avatar
7 Second Club
I run ls7 lifters goes threw the stripe at 7850ish .635 lift with btr 660 dual springs
Old Jan 19, 2020 | 08:42 PM
3 window's Avatar
Any set up at .060 from coil bind?
Old Jan 20, 2020 | 01:43 PM
RonSSNova's Avatar
I didn’t. BTR duals and LS7’s.
Not sure that’s necessary unless you are pushing limits.
Do you have a valve spring tester? I’d think a guy would want to know the resulting spring pressure after shimming to within .060” of coil bind.
I’ve no clue what the “LS7” lifter limits are. I have them I’m both my engines. One set is great, the other set seem to have a high bleed rate.
Ron
Old Jan 20, 2020 | 07:58 PM
3 window's Avatar
Ron
Based on the rate of the .660 spring being 370, it’s easily calculated.
Coil bind height (1.070)+.060+lift (.570 in my case)=new installed height (1.700).
On the seat at 1.78 = 155
rate x reduction on installed height + original seat rate = new seat rate ([370 x .080]+ 155) = 184.6.
 Michael S. Palmer
