What should I expect and where to draw the line
Old Feb 14, 2020 | 06:44 PM
lowlifegm's Avatar
Default What should I expect and where to draw the line
So long time lurker on the forums been gathering information and parts far some time now. Motor is going into a 03 s10 Xtreme. Going to mainly be a street truck and will see some track use eventually. trying to see what people think my limits should be power wise to try and keep it together but I also want to see what it can do
Lq4
arp main studs
arp head bolts
arp rod bolts
melling high volume oil pump
new rod bearings
new main bearings
gen 4 rods
rings gapped for boost
stock 317’s with pac 1219
Texas speed stage 3 turbo cam
tsp pushrods
holley Hi ram 105mm
holley 105mm throttle body
snake eater 1500’s
-8 feed -6 return
e85 content sensor in return line
dual 450’s in tank
4l80e stock converter (for now)
hd2 shift kit
holley term x max
Borg Warner s480 87mm 1.25 ar t4
Old Feb 14, 2020 | 07:24 PM
ls3fox's Avatar
7 Second Club
Why the 87 t4? Should go with a 96 t6 and if the tune is good turn it all the way up
Old Feb 14, 2020 | 07:40 PM
lowlifegm's Avatar
I bought the turbo and the hot side early on in the build with eager eyes haha
Old Feb 15, 2020 | 10:11 AM
RonSSNova's Avatar
Sounds like a solid setup. Should go 20 psi safely. Just sneak up on the tune and boost. 15-17 degrees timing.
Keep an eye on fuel pressure.
It will go faster than you think!
Old Feb 15, 2020 | 10:09 PM
truckdoug's Avatar
gotta get that fti converter in the parts for sale section
Old Feb 15, 2020 | 11:00 PM
lowlifegm's Avatar
believe me i see him bump the post everyday and it’s taking lots of self control to not spend money I don’t have. I had the motor and transmission next to each other for a few weeks and kept telling myself “a converter and then I can put them together” and about a week ago i decided to say screw it and put them together with a stock converter and onward with getting the truck up and running
Old Feb 15, 2020 | 11:04 PM
lowlifegm's Avatar
thanks for words of encouragement! I can’t wait to turn it up and see what it will do!
Old Feb 16, 2020 | 02:02 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Lq4
arp main studs
arp head bolts
arp rod bolts
new rod bearings
new main bearings
gen 4 rods
tsp pushrods
holley Hi ram 105mm
snake eater 1500’s
-8 feed -6 return
dual 450’s in tank
hd2 shift kit
holley term x max
Rip your power potential in half, and you will still be able to do 80mph freeway burnouts. I have no idea what you will do with this ride, but you should be looking into suspension now, as your motor is covered.
Old Feb 16, 2020 | 09:47 AM
truckdoug's Avatar
we go to about 450-500wheel on the stock 80e converters and they're ok. after that they blow right through up top. and always play in D3, unlocked
Old Feb 16, 2020 | 11:43 AM
lowlifegm's Avatar
good to know, thanks Doug 👍🏻
Old Feb 17, 2020 | 09:31 PM
rpturbo's Avatar
Just fyi packaging on this will get tight, real tight, real fast. You'll have a hole in the hood for the high ram (not that it's a big deal just fyi) and you will hack up the core support or make a tubular setup. There is just not a lot of room from the front of the block to the core support, so placing that turbo in the right place is required. It's easier if your just dumping exhaust out if the front fender though. Can't wait to see progress.
Old Feb 18, 2020 | 03:33 PM
slocaddy's Avatar
Ill second the fti converter, when you have the opportunity get one , ive been in two different/yet similarly built trucks and love the characteristics of them, so much that i just had my other brand converter gone through by them because of trans failure.
Im no cam expert, and big cams, well, i like big cams and i cannot lie. But..... as that was what i wanted, but when i described "street " as being the cars main duty, a stage 1 was what i was sold to me. So now, i have to say, while i might be missing some "rowdy sounds" it certainly preforms on "street" level rpm's/driving. So im not saying you cam is bad, because quite honestly one Company's stage whatever is different one to the next, and you will have power in spades no matter what you do. What im trying let you know is you wont be able to exist on "the street/mexican roads" very long at all at those higher(where the higher"stages" typicly perform) rpm's because you will have to let off.
prob im justa b%tch.
Old Mar 1, 2020 | 06:17 PM
lowlifegm's Avatar
So wastegate question. If I’m using Holley term x for boost control with dual Mac valves being fed by onboard air, should I run a spring in the waste gate? No spring? Just wondering if there is a general idea to follow here
Old Mar 1, 2020 | 07:22 PM
islander033's Avatar
7 Second Club
I run a 4psi spring. You need something to keep the gate closed on low boost.
Old Mar 1, 2020 | 08:01 PM
lowlifegm's Avatar
isnt that what running dual solenoids and on board air is supposed to do? I’m not apposed to running a spring and I have wastegates setup with 7psi sprigs in them now. Just curious if I should or shouldn’t 🤷🏼‍♂️
Old Mar 1, 2020 | 08:24 PM
7 Second Club
I would still run a small spring. What if you break a air line or compressor craps out?
My setup requires 3psi to activate any boost control thus I use 4lbs spring. Not sure how you’ll have yours setup....
