Engine break in on Ethanol
Old Feb 26, 2020 | 03:57 AM
BCNUL8R's Avatar
Default Engine break in on Ethanol
There are a lot of theories on engine break in. I'm curious what are peoples thoughts on using Ethanol during break in and if there is any science behind it. I do my own tuning so I can make sure the car isn't running rich in fact I usually set my idle AFR on the gas scale about 15 instead of the normal 14.7. I plan on doing initial break in on E50 or 50% ethanol. I couldn't really find any answers on whether ethanol actually prevents rings from seating or the extra fuel requirements of ethanol will wash down the cylinders. This is a boosted motor so during initial street tuning it will be much easier to avoid detonation with at least 50% ethanol. I figured after it's broken in and the tuning is getting close I will raise the ethanol percentage.
Thoughts?
Old Feb 26, 2020 | 08:42 AM
transam69230's Avatar
30psi pulls once the car is warmed up ( less than 2miles ), well at least that's what I did.
Old Feb 26, 2020 | 08:47 AM
BCNUL8R's Avatar
I’m not interested in theories on how hard to break it in. I’m interested in whether using ethanol during break in is bad or not. Kind of like it’s a known scientific proven fact that synthetic oil is bad for break in.
Old Feb 26, 2020 | 08:53 AM
ddnspider's Avatar
Ive seen elsewhere online where people said that something in the higher E content fuel makes it more difficult for the rings to seat. Several people said they had break-in issues on E. Not scientific, but real world experiences.
Old Feb 26, 2020 | 09:09 AM
AwesomeAuto's Avatar
You don't honestly think that all of those methanol/ethanol burning race cars break their engines in with gasoline?
You can get a fuel lubricant for alcohol fuels. Use that if you're worried.
Old Feb 26, 2020 | 09:25 AM
DBRODS's Avatar
90% of everything I build is on E85. Fresh motor gets 3 heat cycles and drain oil and change filter. Then it gets as much boost and rpm as I can put into the setup. Change the oil and filter again after tuning is done. Motors live a happy life.
Old Feb 26, 2020 | 09:34 AM
BCNUL8R's Avatar
I wouldn’t say I’m worried, but interested if there is a preference with fuel types during break in. I’ve had good luck breaking in motors by putting them through a heat cycle then changing oil and then start tuning. This will be my first engine break in using ethanol though so thought I’d ask.
Old Feb 26, 2020 | 10:13 AM
LilJayV10's Avatar
it is?
Old Feb 27, 2020 | 01:54 PM
slowride's Avatar
It probably depends if you have the tune pretty solid from the past or if you end up over fueled for too long at startup messing with stuff. I'd probably prefer to break in on gas as does my machine shop guy, but it's not the end of the world if it's pretty dialed in from the last setup.
Old Feb 27, 2020 | 03:45 PM
sctrance's Avatar
The synthetic oil break in thing is a myth for modern engines, might have been something to this back in the day when parts with rough surfaces and lesser materials really needed to bed in but with the improved parts, materials,and machining finishes used these days engine break in is not much more than a leak check.
But I have had problems with synthetics in my E85 combo prematurely turning black and staining the internals. Did some research on the most alcohol compatible oils and ended up using VR1.
Problem solved, oil never gets dark or discolored prematurely and the staining is gone when I pulled the motor apart recently after a year of use.
Old Feb 27, 2020 | 04:35 PM
BCNUL8R's Avatar
That's odd...I've been running synthetic oil and E85 for the last 2 years with no issues with the oil. It was always clean. In fact I tore the engine apart while it was still in good running condition because I wanted a forged motor and it was the cleanest engine I've ever seen inside.
Old Feb 28, 2020 | 01:25 AM
subeone's Avatar
Run e85 m1 93 or whatever u want. Wont affect break in. I dont even break em in, turn em on, straight to the dyno.
Old Feb 28, 2020 | 04:41 AM
BCNUL8R's Avatar
I believe in breaking them in hard, but at least one heat cycle and oil change can’t be bad for it. I tune on the street so even after that first heat cycle and oil change it’s not like it’s going to be instant wide open throttle, but I will not be babying it either.
Old Feb 28, 2020 | 07:06 AM
I usually let them get one heat cycle just to flush out gunk lol.
Old Mar 1, 2020 | 09:20 AM
minytrker's Avatar
I tune new engines on the engine dyno all the time. We get them up to temp, do a little pull to like 5,000 rpm check the log and then do a full pull. This is done on everything from ls motors to $100k race motors.
