Smoke Cloud on Restart
Old May 1, 2020 | 08:45 AM
2000WS6TA's Avatar
Originally Posted by jordoza
My plugs showed awesome too cause smoke show was caused by the turbo after the engine. Valve seals would be smoke on start up after sitting overnight. Oil leaks past the seals into the cylinder so its burned on start up. That doesnt fit your symptom.
gotta be something in the turbo lines then.
Old May 1, 2020 | 09:02 AM
tblentrprz's Avatar
If valve seals, oil on plugs. If turbo, plugs clean and oil on post turbine O2 or in downpipe. Turn off and check 5s after smoky start.
