D1SC radiator to keep ac
Old Apr 29, 2020 | 07:56 PM
txh0tb0i972's Avatar
Default D1SC radiator to keep ac
I currently have a lt1 radiator, I’m needing to replace but don’t have too much info which one I should go with.
any help with your setup/part # would help
Old May 1, 2020 | 07:18 PM
500@10psi's Avatar
Im confused at what your asking as long as you have the ati fan setup any stock type radiator will work fine
Old May 3, 2020 | 06:49 PM
007FJ's Avatar
IMO buy the Dual Pass Griffin in the standup radiator thread with a Mighty Mouse Shroud is my thinking plus it helps with the continuous suck of the air filter BS with a Procharger.
I had a stock size Griffin, then a Be Cool moved forward a couple inches and a smaller Condenser, and finally the bigger dual pass Griffin because I kept trying to improve the air filter clearance on my F1C before I went Huron Speed T4 V3 AC.
Old May 4, 2020 | 11:30 AM
Ping King's Avatar
I had a dual pass unit made by BeCool. It had a single 16" fan as well as an aftermarket condenser. The radiator shroud was cut and moved forward. This is for a turbo car, but there is TONS of room in the front for whatever air filter setup you'd need.
