CR suggestions for turbo E85
Old May 2, 2020 | 12:28 AM
ZachJ03's Avatar
Default CR suggestions for turbo E85
I am looking for compression ratio suggestions for my build. I have a Gen 4 aluminum block 5.3 and going to do a forged rod/piston combo with new bearings etc.. It will be a turbo set up with A2A intercooler on E85 and ran with Holley HP EFI. Also, 243 heads. I’d like it to handle 20-25 psi. I was thinking 10:1 but the machine shop that I took my engine to acted like that was too high. Any input or suggestions are appreciated.
Old May 2, 2020 | 10:51 AM
AwesomeAuto's Avatar
I've done over 30 PSI with 13:1 on E85.
Old May 2, 2020 | 11:28 AM
01CamaroSSTx's Avatar
So is it safe to say that I could throw boost on my LS370 which has 12:4.1 if using E85? Are you also using meth injection with the E85?
Old May 2, 2020 | 11:30 AM
I'm going to have to call
Old May 2, 2020 | 02:34 PM
tblentrprz's Avatar
How much boost do you plan to "throw" at it? What rpm will it be run at? Do you have a competent tuner to define timing strategy? Do you expect to reach MBT at boost > 20psi?
Old May 2, 2020 | 09:21 PM
Razor's Avatar
9.5 - 10.5 static on a street car sounds about right.
Do yourself a favor and google the topic. There are several articles and videos reference the subject that provide a good explanation of the effects of increasing static compression ratio vs. boost pressure. More static compression is not always a good thing.
Old May 3, 2020 | 09:24 AM
13:1 static with 30psi on E85 is definitely not street car territory which got my attention. I'm sure there's more too this story but like always there are plenty of people on here that pop off remarks but doesn't answer the questions.
Old May 3, 2020 | 12:10 PM
tblentrprz's Avatar
Sorry OP to derail earlier. Is this a street car? Wheel hp goal? Depending on goals, planned rpm and cam specs, will ultimately dictate where to spec static compression. Did your machine shop talk about/ask these things? If not, may not be the ideal place to work with. Either way, 5.3, e85, street car and max 7500rpm, I would run at least 10, target 11-1. This will generate good cylinder pressure and temperature when out of boost. Get up to temp quickly and safe with good tune. Lower SCR is more forgiving (wide tuning window especially with e85) with timing, etc. with boost >15+ psi.
Old May 3, 2020 | 07:25 PM
Mine wasn't an LS engine.
Jakson ran 12.5:1 on his destroked 6.0 with about as much boost. His build is on here in detail.
Static compression means very little. Dynamic compression matters more.
Bikes like the R1 have 13:1 compression ratio and run fine in 91 octane. Don't get scared by big numbers.
Old May 4, 2020 | 12:20 PM
NicD's Avatar
7 Second Club
Shoot for somewhere around 9.5 to 10.0 and let the boost do the work, you will have a MUCH larger tuning window and turbos love higher pressure ratios anyways. Plus your big limitation is keeping the heads on the block no matter what fuel you are running, and while E85 is good its also not very forgiving at the limits like any alcohol based fuel.
Old May 4, 2020 | 03:29 PM
Yet the guys at Baker talk about completely pegging their GM IAT sensor with 11:1 compression on a non-intercooled setup with E85 and 20 PSI and 20 degrees of timing on a junkyard shortblock.
Old May 4, 2020 | 06:36 PM
gsteele's Avatar
Link?
gsteele's Avatar
Please?
Old May 4, 2020 | 09:08 PM
ZNix's Avatar
I wouldn't personally build anything with less compression than 10.5:1 on E85 and boost.
Old May 4, 2020 | 09:27 PM
gsteele's Avatar
That is not much boost. What if you went higher?
Old May 4, 2020 | 09:29 PM
gsteele's Avatar
And yes, since sarcasm is difficult to pick up on the internet, I was trying to be sarcastic.
Old May 5, 2020 | 07:19 AM
973800CamaroRS's Avatar
People who are running anywhere in the 9-1 range are leaving a lot of power on the table. at least 10.5-1 even higher if everything is planned and tuned right
Old May 5, 2020 | 08:09 AM
ddnspider's Avatar
Originally Posted by 973800CamaroRS
People who are running anywhere in the 9-1 range are leaving a lot of power on the table. ...
Not really. The difference in 9.5:1 and 10.5:1 is generally 3-4% of NA power. If you have a 400whp NA motor thats 16whp.....now add 30 psi, thats 48whp difference total. That's about 2 psi of boost lol. You end up with a larger tuning window at the lower compression. Doing it over again I would have dropped my CR by half a point or so to widen the tuning window for pump gas. That said E seems to not care about boost or CR anyways
Old May 5, 2020 | 08:34 AM
I disagree so much with the 3-4% especially with power adder cars. No one figures in how much better higher compression spools, how much easier it is to make boost on the transbrake, etc, etc. Sure the gains may seems small but figure guys are spending thousand of dollars on intakes or other items that might gain 20horsepower. The more power you make the harder it is to make more so why leave power on the table.
Old May 5, 2020 | 09:06 AM
ddnspider's Avatar
Spool rpm doesnt make more power. Making boost on the transbrake doesn't make more power. They both can lower ET not make more power. Your post specifically said power, if you want to argue it lowers ET, sure. Most street cars that are boosted on here aren't spending thousands of dollars on intakes to gain 20hp, they turn it up 1 psi and make more than 20hp. It sounds like you're arguing race car stuff.
Oh, and I already accounted for the power gains with boost. You can't make more than double NA power at 1 bar of boost. 4% of NA power is doubled at 1 bar. I accounted for 2 bar of boost PLUS the gain of NA power.
