Cam for 5.3 S480
225/238 .612"/.585" 113+3
Good and peppy out of boost and lights quick.
If you watch Richard Holdener, you’ll see similar cams will give similar results. Wouldn’t even be able to tell the difference i bet with the proper converter and gearing.
You can get into valve events and optimize everything... but you won’t leave that much power on the table if you don’t (unless you match something drastically wrong)
