Summit Racing STG 2 (shim advice)
Would you suggest putting a .060 shim under the springs? I'm aware I'll need to check them. But I haven't ordered parts yet and don't have it apart. I'll double check b4 install. Just wanting a ball park to order shims.
Valve Spring specs are as follows: •155 lbs @ 1.780" •380 lbs @ 1.180" •400 lbs @ 1.130 •Coil bind @ 1.070"
Thanks
Lastly, you could run short travel lifters or run more preload on your present lifters. The oil aerates and bleeds down which causes a loss of lift at the valve. .070" is our recommendation for LS7 lifters which are close to .165" travel.
