3 or 3 1/2 Down Pipe?
Old Jun 27, 2020 | 10:55 AM
JinglingBaby's Avatar
Default 3 or 3 1/2 Down Pipe?
Wondering if it would make a difference if I went with a 3 1/2 down pipe on my 5.7? VS 7875 billet has 3’’ outlet, I saw guys at SPP on YouTube go up to 3 1/2 and was wondering am I wasting money or would this help performance? Anybody?
Old Jun 27, 2020 | 11:06 AM
ddnspider's Avatar
Just run a cutout off the 3 inch downpipe. Then you can run whatever exhaust and muffler you want for normal use.
Old Jun 27, 2020 | 12:56 PM
rel3rd's Avatar
That's what I did. Seems to work great.
Old Jun 29, 2020 | 02:19 PM
Ping King's Avatar
I'm sticking with a 3" DP for fitment at the moment. I did notice a difference in spool by changing to a full 3.5" exhaust immediately after the K member. The waste gates also recirculate back into the DP at the 3.5" pipe.
People have made 700+ on a single 3" DP, but they're probably leaving some performance on the table. If you have room, go for it. If you don't...i wouldn't sweat it.
Old Jun 29, 2020 | 04:54 PM
Dragframe's Avatar
I agree. I wouldn’t lose sleep over it
Old Jun 30, 2020 | 03:49 PM
Forcefed86's Avatar
120% of the exhaust wheel exducer diameter is the general rule of thumb for peak performance. So ideally 120% of 75mm would be 90mm or 3.5". In reality what ever you can fit is the answer. Dumps are great IMO too.
If you aren't pushing the turbo hard, can't see it mattering much.
Old Jun 30, 2020 | 04:04 PM
Thanks to all, going 3’’ since it will be here tomorrow. Have room for bigger but it should do until I go with new setup. 99 5.7 w Stock heads & Patriot springs 600/610 238/242 Comp cam, 3:73 12 bolt T400 w 3800 stall in 3100# 81 Malibu. 750 Pro Sustem carb. Next up Gen4 5.3 w CNC 799s and turbo cam.
