My LS1 E36 M3 Sedan Drift Build
Spend your money on a good valvetrain/lifters/pushrods/dual valve springs/etc.
Then throw a small, single turbo at it and send it.
You could probably get away with a set of Gen IV con-rods, honestly. But any forged will do. K1, Callies, Eagle, it doesn't really matter... more than likely, your block will grenade before you break a con-rod.
Manton dual-taper, thick wall pushrods. Probably overkill, but the valvetrain is not the area to skimp on.
Link-bar lifters. Low travel, axle oiling, slow leak down. Blah blah blah.
Get all the little stuff out of the way, too. Windage control/crank scraper, vacuum pump, four corner vent lines and a catch can...
Should I just sleeve the block?
There are exceptions both sides of that 700hp number, but it's pretty much on borrowed time anything over that.
It's hard to say if you need to worry about putting ductile iron sleeves in, or not. Only your goals and budget can make that call.
I always assume that LS1 builds start with this limitation in mind, and that ~699rwhp is always the goal. Lol. So my answer is usually the same... stock heads/intake/crank, forged slugs, Gen IV or forged con-rods, a mild cam, and a small single turbo or centri-blower... send it.
As far as a cam we think our Ghost cam would be a great fit for this combo and goals. Specs on it are .600/.575, 222/233, 115+3 with -3* overlap. It's going to have a stealthy smooth idle with the idle speed turned up. It'll work well no matter if your N/A or boosted. All of our Pro LS cams are offered in combos. Click the related kit/combos tab within the overview for a cam to see its available combos.
The fuel system will need to be upgraded. We'd go with a Walbro 450 LPH pump and 60 lb. injectors. Some modifications may be necessary to fit the pump in your stock assembly. While you're replacing the fuel pump it would be a good idea to go ahead and get a hotwire kit for it. We offer this kit from DeatschWerks.
For lifters, we offer our SUM-HT214-16 LS7 spec lifters. We're comfortable with these to 420 lbs. open spring pressure and 7,000 rpm. We like seeing the pre-load on these set between .060-.080". If you're looking for aftermarket we'd recommend looking into Morel or Johnson lifters. We don't carry them but both are popular with the community. Something to remember is not all lifters are the same and pre-load specs vary. This will affect pushrod length.
It's not a bad idea to look into a trunnion upgrade. This is especially true when going to duals with the added spring pressure. We know some folks prefer bushings and some needle bearings. For this reason, we offer both options within our own brand. We offer a trunnion bearing install/removal tool to make the job easier no matter what type you go with.
A while you're in there part to look at would be the timing chain. We offer the SME-143012 LS2 timing chain. The LS2 chain is thicker and more robust than the factory LS1 chain but it's a direct swap.
