Why not Garrett?
Old Aug 29, 2020 | 11:01 AM
  #41
ddnspider's Avatar
I've used loads of different turbos on 4cyl cars, and a good one vs a bad one can be night and day difference everywhere. Now that doesnt always equate to the most expensive being the best, although generally most are all BB units simply because they are better and do perform better than even similar JB turbos.
And saying an extra 200lbft is not achievable at 3000rpm is as silly as saying a PD blower could not generate an additional 200lbft at the same vs another build.
A good well matched turbo vs a bad one, should easily beat that bad turbo everywhere. Little different than most modern turbos far exceeding the designs from say 20 years ago of similar sizes.
Modern smaller units spool far earlier, make more power everywhere than their older counterparts.
But near $3k+ each for a turbo is a hell of a price to pay. Garrett or others would need to offer pretty good data to convince people they are worth it.
Although some of the Gen2 Precisions, and of course the BW EFR's are all similar prices and they do perform very well.
But so do cheaper JB units too.
As said, someone convince someone who does testing to run some back to backs with about $30-40k worth of turbo lol
Why are you comparing a PD blower to a turbo when it's well known a PD blower has near vertical torque? Please show me one TRUE apples to apples v8 turbo where ONLY the turbo was swapped between a name brand and a chinesium and it made 200ftlbs more at 3000 rpms. If it's so common it should be easy to show. Same boost same motor etc.
PS .....NOT a diesel.
Old Aug 29, 2020 | 11:07 AM
  #42
stevieturbo's Avatar
Because the PD reference is because it would be easy to have a turbo setup making plenty of boost at 3k....as OEM's do. Even if most are happy with much laggier setups
And where did I say it was common ? I said it was very achievable. No different than the same difference at 4000, 5000, 6000, 7000, 8000, 9000, whatever.
Get me the turbos and buy me a dyno and I'll test whatever you want lol
Old Aug 29, 2020 | 11:14 AM
  #43
ddnspider's Avatar
Don't change the goal posts now. It is COMPLETELY different than 5/6/7/8000 rpms because nobody runs a turbo so small that has a boost threshold that low on a turbo setup to pick up 200ftlbs at 3000rpms. That's why your argument doesn't hold weight. You keep saying outside of WOT and low rpm. You're not swapping the SAME SIZE turbo from name brand to chinesium and picking up 200ftlbs at 3000 rpms at the same boost. Post a graph.
Old Aug 29, 2020 | 11:18 AM
  #44
If I ever do the test....I'll post the graph. Still waiting for sponsors.
Old Aug 29, 2020 | 11:32 AM
  #45
ddnspider's Avatar
Gofundme?
  #46
gsteele's Avatar
Hang in there. We understand your point. BTW, love it when you use the word "whilst". It is so British.
Old Aug 29, 2020 | 12:09 PM
  #47
SLOW SEDAN's Avatar
As mentioned before, the new turbine wheels Comp are showing do look a bit different than typical
That comp wheel sucks ****, tested that one back to back with a Borg and results were not inspiring.
Old Aug 29, 2020 | 01:07 PM
  #48
Project GatTagO's Avatar
So...what I am hearing is that if cost is not an issue, a 5.3L with a pair of G25-660 would make an amazing street combination...LOL
Andrew
Old Aug 29, 2020 | 04:50 PM
  #49
Andrew
China fans would say never ! never !
But it would make a very good test. Although a friend is building a car with a pair of G3-900's on a 7.0 LS....so that should be equally interesting. More so as it will only weigh around 1800lbs
Old Aug 31, 2020 | 11:12 AM
  #50
I like the g25s because of the turbine housings with the built in waste gates. I am sure that many hear would say that the internal wastegates will have a problem controlling the boost level on a 5.3L...Any thoughts on that?
Andrew
Old Aug 31, 2020 | 11:14 AM
  #51
ddnspider's Avatar
I'm not against name brand turbos at all if the need/build calls for it. This new series of Garrett's do look interesting. I just don't like that people assume the setup is trash because someone isn't using brand XYZ turbo.
Old Aug 31, 2020 | 11:19 AM
  #52
I don't believe that I ever made that assertion. I am just trying to understand if there are technical arguments against using the new G series turbos, without bringing price into the discussion.
Andrew
Old Aug 31, 2020 | 11:35 AM
  #53
SLOW SEDAN's Avatar
Andrew
I've run internal gates on a 5.3 and larger engines before, with both Garrett and china turbos, had no real problems controlling boost with either. However, I did have some issues with total power output on the small turbines.
I think the real problem with the G25-660 besides being $2500 a piece which is silly for a turbo this small, is the 49/54mm turbine wheel. I ran Garrett 58/55's (55/60mm turbine) as well as some others and didn't have stellar results so I cant imagine something smaller would be any better as the only real claim they state for the G25 over a GTX is the compressor flows 10lb/min more which doesn't help if your turbine can't flow enough to support it.
Old Aug 31, 2020 | 11:40 AM
  #54
Andrew
If the gate is well suited to the housing...it shouldnt be an issue. BW EFR' series come with integral gates even on the big units and they work because they are designed to.
That isnt to say an external gate may not work better though
But a G25 really is a little turbine, still don't know of anyone using any of them yet, even on 4cyl cars.
Old Aug 31, 2020 | 12:25 PM
  #55
ddnspider's Avatar
Andrew
Sorry if you inferred I was talking about you. I wasn't.
Old Sep 1, 2020 | 11:23 AM
  #56
Fair enough...It's just the internet...LOL
Andrew
Old Sep 1, 2020 | 02:17 PM
  #57
AwesomeAuto's Avatar
Quad turbos really add up...LOL
Andrew
2 x Garrett GTX3071R with 0.61 A/R Double V-banded Ceramic Coated Turbine Housings (856801-5039S) - $4085.38
2 x Reverse Rotation Garrett GTX3071R with 0.61 A/R Double V-banded Ceramic Coated Turbine Housings (856802-5004S) - $4321.94
Subtotal: $8407.32
Tax, Shipping/Handling - $738.51
Total: 9,145 nopes.
Pretty safe to say that I'll very likely just end up spending (ironically) $1320 for 4x Chinese Billet GT30X /w 0.63 A/R T3 turbine housings and no reverse rotation.
Old Sep 1, 2020 | 03:28 PM
  #58
SLOW SEDAN's Avatar
Subtotal: $8407.32
Total: 9,145 nopes.
Thats a lot of effort to make the same power as a single 76mm, granted you get 10x the scene points
Old Sep 2, 2020 | 03:47 AM
  #59
I made almost 900whp with 4 of the $120 turbos on a 4.8 an ran 9s with over 300whp less.
I'm aiming for ~1300whp on the next setup.
Old Sep 2, 2020 | 09:09 AM
  #60
SLOW SEDAN's Avatar
I get that it works and its different but plenty of 76’s (even cheap chinese ones) make over 900 and run 8’s. Either way have fun!
