Low power for a 408 stroker/F1R?
Old Sep 20, 2020 | 03:48 PM
Red02ss35th's Avatar
Default Low power for a 408 stroker/F1R?
Hey guys I have a question. I have a 408 stroker/stock ls3 top end studded w/ ls9 gaskets with a F1R procharger and a 4" vs racing intercooler. M6/9" 3.50 gears. With 11.1:1 compression on e85. I made 16lbs with a 7.65/4.25 pulley setup and only made 703whp. Is that low for such a big blower? Cam spec is for NA stroker 242/248 636/636 112+3LSA 20* overlap. Also after a several pulls iat goes to 150*. Normal?
Old Sep 20, 2020 | 09:46 PM
AwesomeAuto's Avatar
I think my junkyard 4.8 made more than that at that boost level and through an auto trans. It does seem pretty low.
Old Sep 22, 2020 | 03:50 PM
blackdak318's Avatar
I would say that is very low for that combo, yes. I'd say you're about 100-150 RWHP short. I'm not a centri cam guru but 20 degrees of overlap seems like a lot?? May be bleeding a lot of boost off in the motor. Something to check.
Old Sep 22, 2020 | 04:31 PM
BCNUL8R's Avatar
I'd have to guess it's the cam if you are actually at 16 lbs and pulling clean all the way up.
Old Sep 23, 2020 | 01:59 PM
V8sounds's Avatar
What does Timing and AFR look like?
Old Sep 23, 2020 | 03:12 PM
Timing I'm not sure I'd have to ask my tuner. Afr in WOT is like 12.7 the dyno graph I don't have but didn't really drop until about 6500rpms and didn't drop didn't have any belt dust near the blower/bracket
Old Sep 23, 2020 | 03:46 PM
SLOW SEDAN's Avatar
12.7 A/F on 16lbs and 11:1 comp? Sounds like you need a new tuner.
Old Sep 23, 2020 | 04:50 PM
V8sounds's Avatar
I would anticipate this needs to be more in the range of 11:1 for the AFR. Timing makes a huge difference in power. is it at 8 degreees or 20 degrees? That will be a ton of power there.
Old Sep 24, 2020 | 10:53 AM
ddnspider's Avatar
What in the actual crap?!
Old Sep 24, 2020 | 11:59 AM
Yeah, new tuner, immediately.
Old Sep 24, 2020 | 12:57 PM
SLOW SEDAN's Avatar
The tuna's are running wild!
Old Sep 24, 2020 | 01:39 PM
Forcefed86's Avatar
Ever run it on motor? How high are they revving it? I'd agree to get it to a well known LS "boost" tuner, but something still sounds off.
Old Sep 24, 2020 | 04:30 PM
Kfxguy's Avatar
If your afr was 11.7, I would still be concerned. 12.7 is a inevitable catastrophe. that needs to be in the LOW 11's....I've had mine around 12.0 before (2nd pump was off by accident) and it lost ALOT of power.
Old Sep 24, 2020 | 04:41 PM
ddnspider's Avatar
OP stated it's on E85 which is the only reason it hasn't melted itself to death.
Old Sep 25, 2020 | 08:56 AM
BCNUL8R's Avatar
Correct low 12’s even at 11 to 1 compression will be fine on E if timing isn’t stupid. It might not make max power that way but it will be ok.
I think running too hot of a plug with E is more problematic to risk preignition than running a little lean.
Old May 4, 2021 | 11:10 PM
41off's Avatar
Did you ever get an answer as to why your numbers were at least 150hp low? Those are awful numbers for the size of the engine and blower.
Old May 5, 2021 | 10:09 AM
Black_Sunshine_99's Avatar
Maybe your tuner is from the old school where the thought process was "lean is mean" lol.
But seriously, find a new tuner.
Old May 5, 2021 | 11:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am wondering about timing as well. 12.7:1 AF WOT is risky. The higher your compression goes the smaller the tuning window.
IAT's to 150 on a pull, and that's without load. Maybe that intercooler kinda sucks.
LS1Tech Co-Founder
And to keep that safe, your tuner will pull timing as the IATs go from 150 to 200, otherwise you'll go Chernobyl.
