twins on a 4.8ls
Old Jan 5, 2021 | 06:35 PM
joes1966's Avatar
Default twins on a 4.8ls
Im building a 4.8ls budget build and have twin ebay gt45 turbos left over from my last build.I was wondering if anyone has tried spooling anything like these on a 4.8ls.I have a stage 2 turbo cam and pack srpings everthing else is stock.Just wondering if you can get any boost on the brake with these turbos on this small of a engine.Would love to hear what people have done and boost and hp numbers.
Old Jan 5, 2021 | 10:43 PM
AwesomeAuto's Avatar
I've had good luck with more turbo than a pair of GT45s on a 4.8.
Old Jan 6, 2021 | 08:36 AM
SLOW SEDAN's Avatar
Guys spool 94/102's with 6 cylinders, you'll be fine. Better question is if you do get them singing off the line will you be able to hook it?
Old Jan 6, 2021 | 04:11 PM
Forcefed86's Avatar
Tony ran his 351 on a pair of them. Super lazy but made power.... eventually. Little less than the S480 at the same boost number on the same setup. Best I've seen done with them. I think you'd need a 6k converter and an 8k+ redline to make them work well.
2600rpm - 96kpa/0psig
3000rpm - 108kpa/1.74psig
4000rpm - 133kpa/5.37psig
5000rpm - 197kpa/14.65psig
5500rpm - 250kpa/22.34psig
6000rpm - 300kpa/29.59psig
https://www.yellowbullet.com/threads...85-154.996338/
Old Jan 7, 2021 | 04:17 PM
3 window's Avatar
https://www.youtube.com/watch?v=zpSWxsSne14
I’d pull that **** off as soon as it cooled down! Maybe wouldn’t even wait until then.
