Tuning Question
Old Feb 4, 2021 | 07:44 AM
Shownomercy's Avatar
Man-Crush Warning
Default Tuning Question
**Gen 2 LT1, 383ci**
Previously was on HP tuners, 10.5 WOT AFR, 15psi, 18*, no meth, 93 pump. Switched to holley and new hotside.
I just wanted to confirm the process of how to work up to a 15-18psi tune. Hoping to max out my setup on 93 pump gas.
WOT on wastegate (3-4psi) with minimal timing, then dial in AFR. Repeat as needed to get desired boost level, then begin to add timing?
Once I get to timing changes, pull plugs after each pull to verify plug strap mark is good?
