Twin turbo A2A intercooler suggestions
https://www.cxracing.com/intercooler...011-UP-BIGCORE
and
https://www.treadstoneperformance.co...-1300hp/p90650
I like the 3.5" outlet on the treadstone unit, and i feel like treadstone will be a higher quality product compared to CX racing. That being said, the CX racing core is larger. Anyone have any experience with either? Or have any better suggestions on a 2 in one out A2A intercooler? Goal is 1000-1200HP through a 2.5" cold side to a single 4" tube to the throttle body.
I made 1008 rwhp on a mustang dyno thru an unlocked 4L80E. On that pull the details are: 23 PSI total. The starting IAT was 89 and max was 153. So a 64 degree rise on a full 3rd gear dyno pull. Last one of the day so everything was heat soaked. We did have a high pressure fan blowing directly into the intercooler to simulate airflow while moving. It was about 70 degrees in the dyno room.
I honestly am not sure you will go wrong with either. I would personally probably go with the Treadstone because like you mentioned I think it is just a little higher quality overall, and I think performance wise they would be very similar. BUT I do think for the most part bigger = better when it comes to A2A coolers. If you have room for the larger CX unit it may not be a bad idea.
