RaceTCS = the Racelogic traction control equivalent
Very cool. I have a 2010 Corvette with ABS. The trans was swapped for a 4l65E. Would the RaceTCS work on the combination?
I can't see a reason why it wouldn't work. I haven't personally used it on a newer vehicle but it's a stand alone control unit which simply interrupts the injector ground path when dropping a cylinder is desired to reduce power. They have been used on a variety of Japanese and European vehicle too, so it should work on everything but direct injection.
Not like I don't believe you, but emailed Racetcs anyways. Got a quick reply.
Hello
I received email from the shop about technical question.
RaceTCS was tested only with haldex or viscous 4wd cars. It has not been used with a true AWD with central differential. If this will work correctly depends on how the car reacts. If it loses traction on front or rear (depending on conditions), then a firmware update would be required to be able to handle such a scenario. If you have 3 proper locking differentials (like torsens), then the car can easily spin all 4 tires. This situation is something that RaceTCS cannot handle correctly. With one open diff (front or back) this should be easier, as at least one tire should still have traction and the slowest turning wheel could be used as a reference.
So I think it should work? NP149 viscous coupled to a limited slip rear and open front.....
Thanks.
An example is that my front differential is open, so one tire will always maintain traction. With it setup as a 3 channel (which mine is) I have traction control in 4WD because I configured the box to reference the slowest non-driven wheel. Since one front tire is always planted, the other 3 now have something to reference and slip can easily be detected. Works well in icy or snowy conditions. If it were setup as you describe with just a front and rear signal, it wouldn't be able to detect slip in 4WD.
As for wiring into the ECM, both of mine were converted harnesses so they were pretty easy to integrate because I just routed everything where I wanted it. You'll have to break open the harness and find each individual injector ground wire. Each of these will be cut, connected to the RaceTCS input and the other to the output. It wants an RPM as well. It's not overly complex and I suspect it's easiest on your Silverado to do this at the main clump of wires near the ECM rather than at the injectors. There are wiring diagrams online which will help you figure out which color wire is injector 1, injector 2 and so on.
I will also add that there is much more tunability to this thing than I originally thought. For anyone using this on a high horsepower application (turbocharged, supercharged, etc.) I'd recommend widening the minimum slip and maximum slip percentage. I have a 30 to 40 percent difference between the minimum and max figures which has helped smooth things out considerably.
Thanks again.
Thanks again.
As for wiring up the rest of the box there isn't much to it - just power, ground, the LED and ****. I haven't checked for updates in a while but they do seem to keep adding functionality as time goes on so perhaps I'll check in to see what the latest software offers.
If you have a high HP street car and miss using gears 1, 2, 3 - one of these works really well. Highly recommended.
Graph of the unit controlling wheel spin. Two blue lines represent tire speed (front and back) wheels. You can see the unit modulating wheel spin hundreds of times a second on the below run. Works really well on a 900 HP car.
The one thing I absolutely despise looking at the new box though is the connector/wiring, those things are terrible. They should have done standard Deutsch connectors for a much better much more secure connection, especially since it's interrupting injectors.
Full disclosure, the screw terminals were something I added. Not RaceTCS's fault. I prefer the screw type when landing wire. I put in an AC Delco plug at the injector take-off point so that I could bypass the box if there is ever a problem.
I know this is an old post but am looking for help with one of these Race TCS units.
Im running an LS7 and E67 in a kit car. Trigger wheels on rear and front, all appears to be good.
LED light on and blinks correctly when adjusting pot.
If I start logging with engine off, logging runs (no speed, rpm etc of course) and when adjusting pot you can see the preset change. All good.
The problem is, once the engine is started the logging dies after literally a couple of seconds.
ive monitor the TCS led, it stays on as expected. All connectors are sound. Ground is good, but it won’t log.
The unit itself appears to work with some crude settings but it’s far from ideal as if I can’t log I can’t refine it.
ive gone back and forth with Jacek who has been super helpful, but we’ve yet to find a solution hence reviving this old thread.its Hot yo be something small but I can’t find it!
cheers for any help.
If the car is still running, that means the box is still working. I'm guessing the voltage dip on start is messing up the USB connection?
If you havent done so, I would download the latest firmware for RCS and upload, and update your universal USB drivers on your laptop as well
After, I would try connecting the battery directly to the module and see if the problem persists.
