Single turbo front crossover pipe for AC
My original plan was to run a log style manifold with crossover in the rear, but as far as I can tell, theres really no good spot for a bank 2 sensor to run closed loop... please correct me if I'm wrong as I'd prefer to run this setup instead.
So does anyone have any pictures or suggestions of a front crossover setup? Or any suggestions to running closed loop with a log manifold set up?
Thanks.
I have both O2 sensors in my down pipe along with a wideband.
Wire both narrow band O2 plugs from the harness into a single plug so one narrow band is feeding signal to both circuits in the ECM, then just run a single narrowband in the downpipe and let both cylinder banks get the same fueling. That's what I did, but I'm also running speed density OS.
So another beginner question here, but is it less important to monitor o2 on each bank separately in turbo applications like it is in NA applications? Also, I'm tracking how NB sensors reading inaccurately pre-turbo due to higher pressures and such, but are there not NB sensors specifically designed for turbo applications?
Thanks again.
Having the o2 sensors adjust the banks wont necessarily save an engine either. There are a few instances of an injector getting plugged so the computer adjusted everything and it still "looked" good because the other cylinders were running rich to compensate, yet the pugged cylinder popped due to a lean condition. Reading your plugs is going to be the best indicator of how your engine is running.
The one factory turbo car I owned has the O2 sensors after the turbo, but its got twins on a v6 (92 Stealth TT). The newer cars I'm looking at also all have the O2 sensors after the turbos (Taurus SHO)
As for the NB specifically designed for the pressure side pre turbo, no idea.
