Borg Warner secret part numbers
14001013009 Compressor Cover SX-E 76mm, S400 Style, V-Band Outlet S476
14911013013 Compressor Cover SX-E 67.7mm, S400 Style, V-Band Outlet S468
14961013011 Compressor Cover SX-E 72mm, S400 Style, V-Band Outlet S472
14961013020 Compressor Cover SX-E 72mm, SX-E Style, Combination V-Band/Hose Outlet S472
11671013000 Compressor Cover B1 EFR B1
177212 Compressor Cover SX S400 - S471 (T4/83mm turbine) (177248 turbocharger) V-Band outlet style cover
169012 Turbocharger SX S400 T6 A/R 1.10 63.5mm Inducer/ 74.3mm turbine exducer "S463.5" w/83mm turbine
172743 Turbocharger SX S400 CAT C12 & Detroit Diesel 12.7L (with wastegate, forged milled compressor wheel) "Borg Warner K31" aka Billet S471 w/83mm turbine
A/R- unknown, twin scroll, wastegate only bleeds one scroll of turbine housing, the compressor cover is larger than the s475 and still vband charge outlet
These are the Race Cover, the non vband john deere style:
177354 Compressor Cover SX S400 - S475 (T4/83mm turbine) (177101 turbocharger) w/Attenuator
177352 Compressor Cover SX S400 - S471 (T4/83mm turbine) (177248 turbocharger)w/Attenuator
177288 BorgWarner Turbocharger SX S400 T6 S475 A/R 1.32 75mm Inducer w/ Race Cover, S475
Here are some that I don't know what they fit. Does anyone have specs like what size compressor these fit?
177179 Compressor Cover SX S200
177181 Compressor Cover SX S200
177197 Compressor Cover SX S300
177198 Compressor Cover SX S300
177200 Compressor Cover SX S300
177201 Compressor Cover SX S300
177202 Compressor Cover SX S300
177203 Compressor Cover SX S300
177204 Compressor Cover SX S300
177205 Compressor Cover SX S300
177206 Compressor Cover SX S300
177253 Compressor Cover SX S200
177254 Compressor Cover SX S200
177255 Compressor Cover SX S200
Then there are a few turbos that I can't find the compressor/turbine sizes:
177263 Turbocharger SX S200 John Deere 6068/6068T engine
179078 Turbocharger SX S300 95-06 International DT466 7.64L wastegate?
179079 Turbocharger SX S300 International DT466, 61.44mm FMW
179077 Turbocharger SX S300 95-06 International DT466/I530E 7.64L wastegate?
167736 Turbocharger SX S400 Detroit Diesel Series 60 11.1L
478089 Turbocharger SX S200 Caterpillar 3126B S200G
13809880114 Turbocharger S300 (RE532384) 06-09 John Deere Various w/ 6090H Engine
169011 Turbocharger SX S400 T6 A/R 1.58 69.4mm Inducer, meant to replace Garrett TV4502, "S469"
177277 Turbocharger SX S300 John Deere 6081
177285 Turbocharger SX S400
177286 Turbocharger SX S400
174832 Turbocharger SX S400 MACK E7
None of the numbers I listed are in the aftermarket catalog. I got all the numbers from my distributor and having some trouble finding parts for airwerks turbos.
I was trying to find a different cover for the s366 and s475 but haven't had much luck.
