Slowly losing base fuel pressure
Old May 6, 2021 | 06:23 AM
forcd ind's Avatar
The round truck coils use a shorter plug wire, the kind of square ones use a longer wire-I use the MSD plug wires, you can bend the plug side for a better angle. I have one wire (#8) that lays on the down pipe, pipe is wrapped, and wire is insulated, but I still worry about it. I made up a wire with an almost 90 deg end, haven't tried it yet.
