ZR1 Map
Old May 6, 2021 | 11:35 AM
BCNUL8R's Avatar
Default ZR1 Map
Will it physically fit in a ls1 intake manifold map location? I know there are pig tails, but is the size different?
I’ve been running near 20 psi on a 2 bar and it seems like it’s a good time to go to a 3 bar map.
Old May 6, 2021 | 12:03 PM
Fallguy's Avatar
8 had to drill out my Ls2 intake for the 3 bar ZR1. Don’t know if it mounts the same way in a LS1
Old May 6, 2021 | 12:13 PM
BCNUL8R's Avatar
The ls1 uses the little orange seal thing and the ZR1 has the o ring. The intake I’m getting is for an ls1 but does have the screw hole to hold the map in.
I could tap it and install a hose barb to mount it remotely I guess.
Old May 6, 2021 | 05:42 PM
Fallguy's Avatar
yeah the LS2 has the same little orange ribbed deal.
the LS2 has a clip on the side that holds it.
Old May 9, 2021 | 03:38 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Don't take chances. Tap your manifold and remote mount any sensor you want. I learned this the first time I blew a 2 bar sensor out of a FAST manifold.
