Using two WB02 sensors with holley EFI
Old May 13, 2021 | 10:35 PM
Novaray64's Avatar
Default Using two WB02 sensors with holley EFI
Who runs two WB02's ? This is a twin setup with holley efi. Car runs great but my WB02 readings are always different side to side and have alot of peeks and dips, Attached is a log to check out. I have the holley set to use the leanest reading. I dont see any exhaust leaks and I just replaced both NTK sensors.
File Type: zip
Old May 14, 2021 | 10:26 AM
Novaray64's Avatar
I'm hoping that someone can post a data log under boost that is running two WB02's so I can take a look and compare it to mine.
Thanks
