Head stud swap
Old Jun 5, 2021 | 01:23 PM
89mulletbird's Avatar
Default Head stud swap
I'm just finishing up swapping out the 10 big ARP head bolts for studs, I'm wondering if it's even worth the effort to remove the intake to swap out the 10 small bolts for studs under the intake manifold, or should I just wait until I have to remove the intake manifold for other reasons to swap out the small ARP bolts for ARP studs? I'm going from 15psi to 20psi is the reason for swapping in the studs.
Old Jun 5, 2021 | 06:18 PM
DBRODS's Avatar
No reason to change the 8mm bolts. I usually use the stock 8mm bolts with doing 1/2" conversion on the 11mm bolts.
