Best C.R. for 30psi boost
You'll have access to some excellent heads in the Windsor platform making your goals easier to reach.
Per Aeromotive website:
The Eliminator performance you expect and more:
- Fuel Injected Engines: GAS
up to 1900 FWHP – naturally aspirated
up to 1400 FWHP – forced air induction - So E85 forced induction - 980 FWHP
- A1000 E85 forced induction - 490 Flywheel HP
- Total for two pumps: 1470 hp of E85 @ Crank
- Kenne Bell Dual Boost-a-Pump @ 14.1volts ~1500+ hp on E98
Holley 160lb/hr fuel injectors.. Flow matched
I ultimately want 4hp/cubic inch. 347 X 4 = 1388hp @ crank
