How wide (and low) can the powerband be?
I've decided the least important part of my commitment was to diesel like torque when this is a truck that has to do a job so I wanted to open the floor a little more and ideally get some more feedback. I will try to be less wordy this time.
CURRENT PLANNED BUILD:
- Turbocharging a 5.3L Gen3 V8 is the only fixed part - I know a 6.0L would give easier and flatter torque but wanted to save some money there and make the power with and altitude compensate with the turbo
- Forged 4340 rods and forged pistons - specifics to be decided
- Goal (and Ceiling) making 450-550lb/ft of torque "as flat and wide as a table" - this is for transmission life among other things and because i've decided it's enough. Prefer lower as this is for a tow vehicle not a sports car - i'd rather have 1500-5500rpm than 2500-6500rpm.
- Water or water/methanol injection using a 5 gallon DEF tank repurposed
- Intercooler probably taken from a Duramax
- Reliability matters and budget is just trying to be reasonably thrifty
- Reused and repurposed junkyard parts are just fine.
What would you choose for things like turbos and camshaft or other power parts? Consider things like the reliability of the turbocharger under minutes of uphill load so no chinese turbos, that the heads might last longer if they stay iron heads even if losing a little compression, etc.
I'm led to believe twin turbos will spool faster than a single turbo despite the cost, maybe even twin scroll turbos on each side as long as cost isn't excessive.
Power for hours (over the engine lifespan) is just about not having to worry about keeping my foot in it than maxing the load at 60mph. Scariest tow I ever had was actually thru outer Cincinnati at rush hour where if I didn't keep up 75mph on the right people would honk and swarm around me like a logjam. Once past I slowed down to 55-60 again.
