injector and throttle body help
Old Sep 19, 2021 | 12:54 PM
joes1966's Avatar
Default injector and throttle body help
Im going with a truck style intake and a 4303 fuel pump but need to know what people are using for throttle body and injectors.Im also running the terminator x ignition so need something that works for that as well.Im hoping for close to 800 wheel hp on a cam only 5.3 on e85.I head a couple people say you can run the stock style throttle body for that hp but wanted to get some opinions on it.I will be running e85 so the injectors will need to be able to handle the e85.If you have a source you buy from or site would love to hear it as well.thanks so much
Old Sep 19, 2021 | 01:34 PM
Lsxford's Avatar
Bosch 210s is the way to go imo. I got mine from big ****** performance, can find on FB, they come flowmatched and the best price I found.
for throttle body I like to use the eBay 92mm piece. It comes with really stiff return springs so I usually take 1 of them off, it comes with 2. If you have a 3 bolt intake just use the 3 bolt dbc throttle body. Any intake and throttle body will make the power.
