terminator x map sensor chart
Old Sep 23, 2021 | 06:27 PM
joes1966's Avatar
Default terminator x map sensor chart
On the terminator x map chart is Atmosphere at zero or does it start at 14.6.I thought someone said the chart had atmosphere at 0.. Just trying to set the boost map and needed to know how the chart is setup
Old Sep 23, 2021 | 08:19 PM
LLLosingit's Avatar
Map is displayed as kPa but you can change it to display PSI in you want.
On the main screen you can go the the toolbox drop down and then preferences- The you can select to have it display Map as PSIG
Old Sep 24, 2021 | 04:04 AM
joes1966's Avatar
thanks so much I changed it to psi yesterday because it just made it easier for me.I just wasnt sure if 0 was atmosphere or 14.6...thanks again for the post
Old Sep 24, 2021 | 06:47 AM
LLLosingit's Avatar
That's easier for a lot of people including me lol.
Old Sep 24, 2021 | 07:59 AM
Forcefed86's Avatar
With KPA 100 is atmospheric. Below 100 is vacuum. Or right around there depending on elevation. 200kpa would be 14.7lbs of boost. Each 100kpa is 1 bar of atmosphere/boost. Map shown above is an NA map.
