Boost and 11:1+CR
Old Dec 17, 2021 | 08:11 AM
TrendSetter's Avatar
if youre going to open up the quench, consider sending the heads out to have the chambers softened.
i have a 12.5:1 bbc built for nitrous and switching to boost and thats my plan... thicker head gaskets and softened chambers. and e85.
and omg 11.8 afr at 1psi lol
Old Dec 17, 2021 | 08:31 AM
Kfxguy's Avatar
what did you do, copy and paste your same post to two different threads?
Old Dec 17, 2021 | 09:30 AM
SLOW SEDAN's Avatar
Originally Posted by Kfxguy
he didn’t say. And I assumed the op was referring to using pump fuel when he was asking his original question. So to keep someone from breaking their motor, thinking they can get away with that lean of a mixture….so I felt it my duty to warn anyone. My guess is it was a typo or misunderstanding from the poster and tuner. No damn way I’d ever run an engine that lean on boost.
and I’d much rather be safe and leave a little power on the table than be right on the edge and leave engine parts on the street!
And I agree...too rich will hurt the spooling of the turbo....but not a supercharger......unless a d1x is some sort of turbo I didnt know of
I get it, why I always start low and work up. Centrifugal blowers needs revs to make boost, engines rev faster when not choking on fuel.
Originally Posted by tblentrprz
Worth mentioning IAT in the same sentence as boost, timing and AFR in relation to detonation. ECT worth knowing too since it will impact fuel limit and detonation.
True but the impact of IAT is also heavily fuel dependent, E85, M1 etc aren't nearly as sensitive to higher IAT's as pump gas.
Old Dec 17, 2021 | 11:01 AM
i scrolled down into the stupid 'related thread' without realizing it. i deleted that post as soon as it posted.
Old Dec 17, 2021 | 11:22 AM
SLOW SEDAN's Avatar
Worst feature ever!!
Old Dec 17, 2021 | 11:38 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Originally Posted by ryeguy2006a
I'd need to check my tune again, but I know I'm running 18* of timing at 11 psi and I believe my AFR is around 12-12.5:1 I have knock sensors enabled in my tune with Terminator X and it had no signs of knock. My tuner said that if I wanted I could bump the timing up a few more degrees. But I was only shooting for 600 whp and we had already hit 633, so I just kept it there where it was happy. I should also mention that I gapped my rings per Mahle's instructions for a supercharged car. .024/.026 top and bottom. I've been reading a lot about what fails on the LS cars when boosted and the common thread seems to be ring lands.
OP if you aren't properly gapped, I would suggest addressing it now before something breaks.
12.5:1 sounds lean for 11 psi, but what compression is the engine? 93 pump right?
Old Dec 17, 2021 | 02:31 PM
Kfxguy's Avatar
pahahahaha! Been there!
Old Dec 18, 2021 | 03:03 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Yes, I have only run 93, sorry I should have mentioned that.
I can't comment on e85 yet because i have no experience with it.
Since you are super safe guy, I will let you know that if you ever run pure meth in the WW tank instead of 50/50, it will eat the pump seals and spill it all in your parking spot. To be specific, I mean it will eat the WW pump at the bottom of the tank, not your meth injection pump. I originally used the WW fluid reservoir on my 2004, but found all my meth on the garage floor in short time.
Old Dec 18, 2021 | 11:38 AM
Kfxguy's Avatar
damn. Didn’t know that, thanks for the heads up! I’ve been good with washer fluid and two bottles of heet so far.
