Tall Deck blocks and FI
Old Jan 9, 2022 | 06:38 AM
aventino123's Avatar
Default Tall Deck blocks and FI
For a pump gas 1400hp FI motor, everyone on here seems to go 408" or 427" or maybe 440". Doing the math it's only around $100 extra in a short block to buy a tall deck Dart block and run a 468" or 480". I'm all new to the LS platform, Last build was a roots 540" BBC, and for BBC the 540" seems to be a well used size with a decent rod stroke ratio of 1.50:1 and plenty of piston to fit a ring set. I just did what everyone else was doing. A 4.250" crank in a tall deck skirted LS Dart block doesn't need clearancing, gives even better rod stroke ratio than my old 540" and plenty of room for a decent piston. Seems an obvious choice so what am I missing? School this LS newbie.
Old Jan 9, 2022 | 08:44 AM
01CamaroSSTx's Avatar
IMO aftermarket blocks are always a better option then the standard production blocks and to reach big cubes on those require a re-sleeve and by the time you invest into that you could have had an aftermarket block. If you have the room then go tall deck, it allows to build even more cubic inches reliably and run NOS or FI. Who wouldn't want 500ci of LS motor under the hood.
Old Jan 9, 2022 | 10:16 PM
blackdak318's Avatar
You need to specify what FI. With a roots/screw blower or centrifugal supercharger I would go bigger as you outline. However, I think a lot of the guys you mention who have the 388-427" motors have them because they're turbo cars. A 427 is more than enough to spool any large frame turbo and anything more than that starts limiting you on the turbine side with back pressure when you get into big power numbers. Hell there are guys out there spooling 106mm turbos on 5.3 motors. Quite simply on a turbo motor there is no need for more cubes.
Old Jan 10, 2022 | 01:05 AM
AwesomeAuto's Avatar
Cubic inches are needed to make big power on pump gas. They aren't needed to make big power as a general rule.
Old Jan 10, 2022 | 07:21 AM
I'm running a gear drive procharger. From what you're all saying for pump gas the extra cubes at not much cost might be beneficial. I'll see what the parts bill looks like for an off the shelf tall deck vs maybe a 427 short block and go from there.
Old Jan 10, 2022 | 08:05 AM
Black_Sunshine_99's Avatar
No expert here and zero experience with Procharger's but I think a 468"+ LS with a big Procharger would make a ton of power easily on even low boost with pump fuel.
Plus there's something awesome about a 500" LS with an F3-134 or something hanging off the front.
SAM runs a 500" LS in Judson's wife's car in the low 9's iirc, its awesome.
Old Jan 10, 2022 | 12:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I maintain an LS record list, and there are some tall decks on there, typically nitrous and blower.
Old Jan 10, 2022 | 01:00 PM
Well there's many of Street Outlaws with a PLR 481X, Hemi or BBC with twins so who's to say that turbos don't belong on big cubes.
 Michael S. Palmer
Old Jan 10, 2022 | 01:57 PM
LS1Tech Co-Founder
Absolutely.
Old Jan 10, 2022 | 02:42 PM
973800CamaroRS's Avatar
Its about longevity...... Cylinder wall thickness, the thicker the stronger. The longer the stroke or longer the rod the less reliable it is, more leverage to bend the rod and more side loading on the cylinder walls.
481X, BBC, Hemi, all totally different layouts and geometry compared to an LS platform. Comparing a $8,000 short block to a 20,000 shortblock.
Old Jan 10, 2022 | 03:18 PM
https://www.enginelabs.com/engine-te...ower-with-nre/
Old Jan 10, 2022 | 03:44 PM
Love that intake. The rod stroke ratio with the 4.375" crank is around 1.45:1 which is way off where I'd be comfortable for longevity. Off the shelf 4.250" and a 6.46" rod fit more comfortably in a tall deck block imho.
Old Jan 11, 2022 | 10:53 AM
LS1Tech Co-Founder
I think one of the 3 second guys, Carlton, ran a tall deck.
Old Jan 11, 2022 | 11:10 AM
rotary1307cc's Avatar
A tall deck makes a beautiful high power, durable 4-in stroke engine
Paired with a 6.350 rod you get it an excellent compression height with plenty of room for a super stout piston
And the piston is completely contained in the bore at bottom dead center
Old Jan 11, 2022 | 12:00 PM
The man has built some wicked *** motors!
Old Jan 11, 2022 | 12:28 PM
https://www.youtube.com/watch?v=L1P-...nracingengines
He has but his business has progressed to the point where he charges an arm and a leg which hey good for him.
There are many other builders out there who also build well engineered, reliable high powered combinations that don't charge for the name.
Old Jan 11, 2022 | 03:04 PM
Bryan with LME or Erik Koenig of HPR are other places you'd expect to pay more to have an engine built and a good reputation will generally merit an increase in price. There's also some crooked SOB's in this line of work too that'll steal your parts and say you have something that you don't which is why there's the saying "You get what you pay for." First engine I ever built was an LSX427 and a special thank you to Joseph Potak for his book "How to Build and Modify GM-LS Series Engines" and to Texas Speed and LME for the parts and service.
Old Jan 11, 2022 | 04:33 PM
LS1Tech Co-Founder
I have a pretty short list of engine shops that I'd reccomend. Very short list.
Old Jan 11, 2022 | 06:00 PM
tblentrprz's Avatar
You're talking 3500+ hp not 1400 and 4x LS budget.
Old Jan 11, 2022 | 08:02 PM
LS1Tech Co-Founder
All that Street Outlaw stuff as said is at a whole 'nother level, I'd bet most of them are running filled or solid blocks, aluminum rods, dry sumps.
