Diagnose friend's combo issue
Old Feb 4, 2022 | 02:37 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Diagnose friend's combo issue
I've got a friend with swapped 72 Malibu, gen III 5.3, twin GT45s, T400, MSD 6014. He's just hit it with 7 psi, maybe that's 600hp. After a year of driving it, it misses at 4500 and breaks up. He's changed sensors, wires, checked voltage, even does this NA. Summit stage 1 cam + their beehive springs. Any suggestions besides "change sensors, wires" he already did. Thrust looks ok. He was running BR7EF gapped at .028 and then .020. Now with the turbos off he's been running TR5s gapped at .040. 8 lbs fuel pressure.
Old Feb 4, 2022 | 02:58 PM
Black_Sunshine_99's Avatar
So it drove fine for a year and started breaking up at 4,500 rpm and higher or just at 4,500 rpm?
Was it N/A for a year then started breaking up once the turbos went on?
8 lbs. of fuel pressure, is it carbureted?
Coil packs?
Old Feb 4, 2022 | 03:39 PM
LS1Tech Co-Founder
-fine for a year
-turbo first, pulled them off to try to fix theproblem.
-carbed, 6014
-new Delco coils to help fix the problem, new coil harness
Old Feb 4, 2022 | 05:39 PM
ddnspider's Avatar
Does it break up at 4500 in neutral or just under load? Logged fuel pressure?
Spark should be able to be verified as well revving in neutral with a light.
Old Feb 4, 2022 | 06:23 PM
GMCGreg's Avatar
Afrs, wide band ? Fuel pressure maintained under load not just at idle ?
Old Feb 5, 2022 | 11:16 AM
tblentrprz's Avatar
I suspect failing coil(s). Anyway to see misfire data? With a scope and current clamp you could record coil power (sync off crank sensor or #1 fuel injector) and see how coils are responding under load.
Old Feb 5, 2022 | 12:11 PM
slowride's Avatar
IDK if AFR is fine swap the MSD if you can find a loner.
Old Feb 5, 2022 | 09:57 PM
LS1Tech Co-Founder
2nd set of coils.
Blow-thru group on FB suggesting various things, base FP is too high, some concerns about whether the carb is set up right. OP is at 8 lb base and a guy in another FB group Boosted LSX said he ran 5/6 lb base and went 9.0@149.
Old Feb 5, 2022 | 10:06 PM
jester1's Avatar
Scope and clamp, power and grounds. You want to see the current and voltage of the coils.
Check also the voltage source to the coils, relay etc.
Throwing parts at a possible electrical problem wont fix the source if it is that.
I dont know how to diagnose or isolate the box itself.
Does he have AFR if so whats it read before and during the misfire?
Has he checked the valve train mechanically by chance? Thinking out loud.
Old Feb 6, 2022 | 02:05 AM
pdxmotorhead's Avatar
Is the MSD mounted on vibration absorbers? if its mounted solid their boxes in general will fail.
I've had all of the CDI boxes fail on road race cars due to vibration, (Broken circuit traces).
Now I use a piece of sheet metal mounted to the car with isolators and then put isolators
under the msd to attach to the piece of sheet metal.
Old Feb 6, 2022 | 06:20 AM
forcd ind's Avatar
I ran my blowthrus with a base of 6 lbs pressure, was fine. Does he have any data on AFR's. I have seen a ruptured reg. dia. cause weird problems, but if did it unboosted, prob not the reason. Prob need to see if pump pressure stays constant, no obstructions. Since he has changed a lot of elect. stuff, kind of rules out everything but the box, or fuel supply.
Old Feb 6, 2022 | 06:43 AM
Bad Apache's Avatar
Agree with others. Confirm power and ground to the MSD unit. Then swap it out. Unfortunately they have issues. In the "old" days, they were rock solid.
Old Feb 6, 2022 | 10:01 AM
jester1's Avatar
^^^ agreed, the solder in the new electronics do not last, in addition they have a lot of cold solder joints that eventually fail. They pass QC but once mounted in vibration prone applications they fail. Car stereo amps are a good example of that.
Old Feb 6, 2022 | 05:56 PM
LS1Tech Co-Founder
Thanks he reads in here and will see your comments.
I also suggested he join this blow-thru group on FB, lots of guys in there with this combo.
I lean towards wanting to drop base FP, him at 8 is higher than everyone else. I have zero experience with a blow thru setup but he's running 2-3 lbs base more than pretty much everyone else who chimed in.
Old Feb 9, 2022 | 09:53 AM
Is the carb he's running setup for up for a FI blow through application?
As I'm sure you know, blow through carbs are significantly modified for those applications when compared to an off the shelf NA unit.
I remember Vortec would put the entire carb in the plenum box to get around this, looked stupid in my opinion lol.
Old Feb 9, 2022 | 10:25 AM
slowride's Avatar
I posted above I'd suspect the MSD first lol especially if it's mounted in the engine bay. Mount that stuff inside on rubber isolaters and away from heat. If we know what the AFR was doing or a trend of how it acts before it breaks up that might help also.
Old Feb 9, 2022 | 11:51 AM
LS1Tech Co-Founder
So he went with an external crank trigger and it appears to work well now, pulled it to 6200.
Old Feb 9, 2022 | 01:13 PM
slowride's Avatar
Interesting, either the MSD changed what it likes or the thrust on the engine opened up? Do you know if it was a 24x or 58x internal wheel/sensor and what he replaced it with?
Old Feb 9, 2022 | 02:26 PM
LS1Tech Co-Founder
gen 3
Old Feb 9, 2022 | 06:41 PM
jester1's Avatar
curious to know if there was any damage to the crank sensor
