Forced Performance HD8892 hp?
Old Feb 11, 2022 | 05:47 AM
Bosshog's Avatar
Default Forced Performance HD8892 hp?
How much power does the 88mm from forced performance usually max out at ? I got a fully built 6.0 and im looking for a budget turbo that'll put down 1200-1300 rwhp.
Edit: dont mind my sig. either that was an old set up..
Old Feb 11, 2022 | 09:58 AM
Black_Sunshine_99's Avatar
I'm not an expert but I don't think that turbine will support 1,300whp on a 6.0.
I think you'd need something with a 100+mm turbine but perhaps someone with more knowledge will chime in.
Old Feb 11, 2022 | 10:14 AM
SLOW SEDAN's Avatar
Be close, the typical billet 80 with 88/96 turbine can do 1100. The stated 92 exducer is bigger than 88 exducer of the typical 88/96 wheel, hard to say without more detailed specs but maybe 100 or 102 turbine inducer?
That said who knows if its $300 better than a VSR 85/102. I think either one could land in the 12-1300 range if you pour the beans to them.
Old Feb 11, 2022 | 09:12 PM
sewerpickle's Avatar
I sell an s400 framed turbo with an 88mm compressor wheel, 92/102mm turbine wheel, T6 flange in either 1.32 or 1.58 ar. Pretty affordable for the budget minded.
Old Feb 14, 2023 | 07:51 PM
musclecity85's Avatar
that turbo should be able to make 1300ish before maxing out. It uses a Garrett gt50 turbine wheel which is bigger then the standard s400 wheel and flows more. I have one the the new one with the new cover on it for my 6.0 it’s a nice piece for the money
