Headgaskets
Old Feb 26, 2022 | 06:40 PM
rt338b's Avatar
Default Headgaskets
I bolted a set of heads on my engine a while back and have never even installed in the car but came across a better set of heads and was wondering if I remove the old set would I need to buy new headgaskets or just swap heads or copper coat the old gaskets tia
Old Feb 26, 2022 | 09:40 PM
3 window's Avatar
I know guys have reused, but I’d replace. Just me. If it popped a gasket after I reused, I’d kick my own ***.
Old Feb 27, 2022 | 06:10 AM
pknowles's Avatar
Yes see above. I replace because the coating comes off the gaskets when removed and that coating helps seal the head to the block. Like 3 windows said, I would be mad at myself for having to pull the whole thing apart again because I was being cheap by reusing head gaskets.
Old Feb 27, 2022 | 09:25 AM
68Formula's Avatar
So to be clear, the engine has never been fired with those head gaskets? They've only been torqued down? No temperature cycling, exposure to combustion pressure cycles, vibration, etc?
Old Feb 27, 2022 | 01:42 PM
rt338b's Avatar
Never been fired or oil primed just assembled as it was to be a spare engine
Old Feb 27, 2022 | 01:49 PM
wannafbody's Avatar
WS6store.com has some nice MLS gaskets
Old Feb 27, 2022 | 01:52 PM
rt338b's Avatar
Have another set of 7 layer small bore btr gaskets was just getting the feel from members on here
