truck manifold help
Old Mar 13, 2022 | 11:58 AM
boostedfirehawk's Avatar
Default truck manifold help
i have a 99 bird that i am putting a truck manifold turbo kit on. i have a 03 4.8 block with a 2000 4l80e trans. i just installled a bmr k member and new oem style motor mounts. the manifolds are non egr from the 4.8. the driver side manifold is hitting the steering shaft. is that normal?
Old Mar 13, 2022 | 02:06 PM
theunderlord's Avatar
Drivers side exhaust manifolds not fitting is a story as old as time my friend.
Old Mar 13, 2022 | 02:48 PM
what are my options at this point?
Old Mar 13, 2022 | 02:52 PM
Depends on how bad the fitment is. if its not too bad, a lot of people use the tried and true method of bashing them with a sledge hammer. (I'm not kidding). If it's really bad you might have to alter the steering shaft geometry, use a double universal joint and a rod end for support. Basically, custom fabrication.
what is the brand of the turbo kit? is it engineered for your specific car?
Old Mar 13, 2022 | 04:03 PM
3 window's Avatar
Cut out the section and modify it. They weld up easily (unless you can’t weld).
Old Mar 18, 2022 | 07:34 AM
Black_Sunshine_99's Avatar
That's interesting, I used the same kit on my old 2002 Camaro and had no issue, is there a specific year of manifold people recommend using?
