Finally retiring the NextGen 78/75
Old Nov 29, 2023 | 03:27 PM
  #41
Black_Sunshine_99's Avatar
Originally Posted by NicD
It's a TR6060 dog box with a strain gauge on the shift lever so I could set up the cuts in the Motec. I can drive it like a normal manual transmission or I can just rip it and not use the clutch or let out of the gas.
Thats legit AF.
Old Dec 8, 2023 | 04:14 PM
  #42
blackdak318's Avatar
Most people jump right to the 88/96 turbine when going to an 80mm compressor. VSR makes one with the T4 housing: VSR 80mm Billet T4 96×88 Turbine wheel 1.25 – VSRacing (turbo4less.com)
But since you already have that one, send it and see what happens. It should pickup, maybe you can grab that 8!
This.
I wouldn't personally consider a turbine even smaller than the standard BW 88/96 an upgrade as even that leaves a little to be desired on a 6.0 IMO. But regardless the car works really well and should improve with that turbo!
