LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Bosch 210's (https://ls1tech.com/forums/forced-induction/1959532-bosch-210s.html)
DETHS5THGEN Jun 13, 2022 12:30 PM
Bosch 210's
I'm leaning toward going with these injectors. Any thoughts on them? Who's running them? $629 a set flow matched from VS racing. Triple pump Fore fuel system with a Huron twin turbo kit for a 5th gen camaro and built 6.0 Dart headed motor.
SLOW SEDAN Jun 13, 2022 01:09 PM
Nothing wrong with them, been using Bosch 210's for years, hard to beat for the price.
Spectre86 Jun 13, 2022 04:15 PM
make sure you get them from a quality vendor. I got mine through Carter motorsports. Alot of people seem to have issues with snake eaters.
jordoza Jun 14, 2022 08:32 PM
I have used the Bosch 210s alot. They work pretty damn good for being as big as they are. Like stated before get real Bosch 210s not the copies. The copies are hit and miss.
DETHS5THGEN Jun 15, 2022 12:42 PM
Yeah I see LSX Willy on FB selling them for even less but I'm pretty sure they're copies. I'll get them from VS racing.
TrendSetter Jun 15, 2022 03:25 PM
i got mine from snake eater. they were sold as 'genuine bosch' from their GB line. i havent used them yet, hopefully they work ok.
Lsxford Jun 15, 2022 09:59 PM
My last build had bosch 210s from big willy performance as does 1 of my buddies turbo 5.3 nova. Worked great and were authentic as far as I could tell. Will prob get another set from him if/when my snakeeater 1500s max out, which so far are working perfect.
mightyquickz28 Jun 15, 2022 10:52 PM
I also got mine (Bosch 210's) from VSRacing. Programmed them into my 0411 and they've ran great.
jayyyw Jun 16, 2022 03:30 AM
Got a set from that seller on ebay. I had them flowed and they were within 2-3%. Idled great and made great power. Had 0 issues with them.
truckdoug Jun 16, 2022 09:57 PM
VSR 210's p59 computer e85 fuel (6.0/80e S480)
man this is ancient history from the BEFORE TIMES
forcd ind Jun 17, 2022 05:23 AM
I remember that truck, did you ever post a build on it.
BCNUL8R Jun 17, 2022 10:41 AM
I’m running a p59 ecu with stock harness and a btr equalizer intake with btr fuel rails. Currently using the tall fuel rail mounts. I also have short mounts and a medium height mount. Are these injectors truck height and the medium height mounts I have will make them plug and play?
https://turbo4less.com/product/bosch...l-application/
truckdoug Jun 17, 2022 11:43 AM
yes but it was destroyed in the great photobucket debacle
rpturbo Jun 27, 2022 12:04 PM
Those bastards!
RonSSNova Jun 29, 2022 11:31 AM
What are you guys using for flow rate? They give two numbers. Dynamic and Static. Both larger than 210 lbs/hour @ 43.5 psi
I’m about to install mine along with a 3.5 bar map.
Stock ECU
Ron
forcd ind Jun 30, 2022 08:42 AM
Are the 210's short like the LS3 injs, I have some short unknows I am starting out with, and have to make brackets to hold the fuel rails, dont want to make them twice. Will be switching to the 210's when I hit the lottery, lol.
rpturbo Jul 3, 2022 02:29 PM
Don't quote me on this, but I believe the 210's can now be bought in 2 different heights.
Lsxford Jul 3, 2022 02:54 PM
Sorry I had to.
There are atleast 2 different heights, the sets I got from big willy were ls3 (pico) height. Shorter than truck injectors, but I believe they have truck height and ls1 height. Would need to ask the seller you're looking at, but you can also get the injector height spacers. I like the ones ictbillet sells personally.
RonSSNova Jul 5, 2022 11:46 AM
https://cimg9.ibsrv.net/gimg/ls1tech...c54b7c0a3.jpeg
210 on the right, LS3 on the left
Ron
truckdoug Jul 5, 2022 02:29 PM
I didnt know you putting more injector on the nova, i figured a wheelie bar was the next item on the list
© 2026 MH Sub I, LLC dba Internet Brands
