Turbo hp rating
Old Jul 25, 2022 | 08:05 AM
Yoji h 123's Avatar
Default Turbo hp rating
What is the hp rating's for borgwarner airwerks 171702 and borgwarner airwerks 179180 and borgwarner airwerks 177287?
Old Jul 25, 2022 | 10:49 AM
SLOW SEDAN's Avatar
Any other details? Engine displacement, compression, fuel, etc?
Usually aren't going to get Borgs listed hp out of them on larger LS's. Like Borg rating the 179180 at 1250hp, good luck with that 82/87 turbine, you'll get closer with something that has the 88/96 turbine.
Old Jul 25, 2022 | 11:58 AM
Yoji h 123's Avatar
325 9.2:1 renegade pro 120+ nitrous for fuel.
Old Jul 25, 2022 | 12:56 PM
SLOW SEDAN's Avatar
That is an odd choice of fuel for a low compression motor and relatively small turbo selection. Any reason you didn't have a billet wheel with the 88/96 turbine in your selection? Are you dead set on Borg offerings? Not sure what your goals are power wise? But if you are going to use fancy fuel and lean on it I would want a little more than an 80mm cast wheel. Borg has an S480 billet offering: Borg Warner S480 SX-E 80/88 110/96 14009097010 but you can get pretty much the same thing for a lower price: Bullseye Power Turbo Billet S480 80/96 T6 1.32a/r V-band- BRAND NEW | eBay can get it even cheaper if you look at VS Racing offerings, the next gen race cover S480 is only $850: VSR 80mm Billet T6 1.32ar – VSRacing (turbo4less.com) take your pick but any of those should get you to right about 1100whp if that supports your goals? If not and you want more power I would look into the S485/102 from various suppliers.
Old Jul 26, 2022 | 08:27 PM
Yoji h 123's Avatar
or what if go with a precision gen2 sportsman 8080 or precision's next gen 8085 sportsman?
Old Jul 26, 2022 | 09:22 PM
sewerpickle's Avatar
Yoji 123 back again. Posting dumb ****.
Old Jul 27, 2022 | 09:08 AM
Yoji h 123's Avatar
Or should I go with a LS2 bored 30 over?
Old Jul 27, 2022 | 10:16 AM
SLOW SEDAN's Avatar
Those are a lot of money for a baby turbine.
Nope, that will just tap out the turbine even earlier.
 Michael S. Palmer
Old Jul 27, 2022 | 12:15 PM
Yoji h 123's Avatar
Or what if I modify it for a 96 turbine?
Old Jul 27, 2022 | 12:51 PM
Yoji h 123's Avatar
What if I swap the t4 to a t6?
Old Jul 27, 2022 | 01:10 PM
Yoji h 123's Avatar
Or what if I swap to a 4.8?
Old Jul 27, 2022 | 01:31 PM
SLOW SEDAN's Avatar
Your going to modify a $4500 turbo, ya have fun with that.
Doesn't matter the wheel is the restriction, you can put a 88/96 wheel in a 1.10 T4 housing and some have gone larger.
Old Jul 27, 2022 | 01:43 PM
Yoji h 123's Avatar
What if I swap it to a 80/96 but with a 1.32 a/r and swap the t4 flange to a t6 flange though. What if I go to billet wheel?
Old Jul 28, 2022 | 10:30 AM
Project GatTagO's Avatar
https://cdn.borgwarner.com/docs/defa...sn=3098b63c_34
Andrew
Old Aug 5, 2022 | 07:03 AM
Yoji h 123's Avatar
What would be the pros and cons in going from a 80/85 to a 80/96?
Old Aug 5, 2022 | 10:10 AM
SLOW SEDAN's Avatar
Already been discussed... go fish
Old Aug 5, 2022 | 12:24 PM
Black_Sunshine_99's Avatar
What in the actual f--k......
Old Aug 5, 2022 | 01:50 PM
Old Buzzard's Avatar
This moron has been at it for quite some time.
Moral of the story... Don't feed the trolls.
Old Aug 5, 2022 | 05:15 PM
68roadrunner's Avatar
what are your goals ?
Old Aug 6, 2022 | 02:51 PM
Yoji h 123's Avatar
1600 or more hp
