Help identifying turbo for 5.3
Specs on the turbo are as follows: (Please do account for possible errors on my part, this is the first turbo i have had my hands on and mistakes are not beyond me.)
Cold side:
76mm inducer
102mm exducer
A garret 6+6(?) wheel that looks either damaged or needed a lot taken off to balance, has an x and a on the back that makes me think its been worked on.
There are 2 straight scratches on the area around the compressor however if something had actually happened to the compressor under load you would think the teeth on the wheel would be destroyed.and the inside would be pretty beat up no?
Hot side:
75mm inducer
82/83mm exducer
Exhaust housing
t4 flange with dual ports
1.28 ar (From reading i think a .81-.96 would be better suited with a 5.3,I would hope to achieve full boost by 3500-3700rpm. Input on this would be highly appreciated as well)
Has the numbers 448940 on the flange which seems to match up with this ( https://gcg.com.au/products/G757707-0003_item.html )
After a little digging it seems to match up with the gt4202 series of turbo however i have taken it apart and found it to be a roller bearing and not ball bearing like said series. This leads me to believe it is the previous generation however i cannot find much info to say for certain. I would like to take this in to have its condition checked by experienced eyes and see what upgrades could be done but I don't know of anywhere near nashville that does this.
i have pics but am also having trouble uploading them.
Any opinions would be greatly appreciated, thanks to all for reading,
