Curious about possible numbers
Old Mar 13, 2023 | 08:46 AM
prostreet513's Avatar
Default Curious about possible numbers
I’m currently working on my new set up and I was just curious what kind of HP and TQ levels you guys have seen based on your experience. I’m more concerned with what it does at the track as the dyno is just a tuning tool but I just wanted some numbers to reference so I can determine if it’s high or low once on the dyno. I know my rear gear will need to likely change. I planned on doing that when I have the transmission done.
Here is what I’ve got:
93 pump gas w/meth
-Holley Terminator-X Max ECU
-GM LS2 6.0 Aluminum Block machine work by BES
-ARP Main Studs
-ARP Fasteners
-Callies 8CW 4340 4.00 LSX Crankshaft
-Callies Extreme H-Beam 4340 6.125” Rods w/ARP 2000 bolts
-Diamond Forged Dish Pistons w/Trend Tool Steel Wrist Pins
-Innovators West 10% OD SFI Balancer
-BTR Custom Blower Camshaft: 235/257 | .638”/.638” | LSA 116
-Katech C5R Timing Chain
-Improved Racing Oil Pan Baffle and Crank Scraper
-Melling High Pressure Oil Pump
-AFR Mongoose LSX 230 72cc heads
-PAC Double .650 springs
-PAC Titanium retainers
-BTR Chromoly pushrods
-LS7 Lifters
-BTR Enhanced 1.7 Rockers
-BTR V2 Rocker Shaft and Trunions
-ARP Head Studs
-BTR Valve covers w/ ARP bolts
-BP Custom Coil Harness
-MSD 8.5mm Plug Wire Set
-NGK TR6 Spark Plugs
-BTR Equalizer Intake
-Nick Williams 102 Throttle Body
-Mighty Mouse Wild catch can
-Lingenfelter 160 Degree Thermostat
-Vortech YSI Blower
-Griptech Billet 3.125 upper pulley
-Turbosmart Raceport 50mm BOV
-A&A Secondary Drive Kit
-A&A C6 Intercooler
-Dewitts Radiator
-Fuel Injector Clinic 1300cc Injectors
-BTR Billet Fuel Rails
-Holley Dominator Dual Fuel Pump
-Holley Dominator Fuel Pressure Regulator
-Alky Control Dual Nozzle Meth Kit
-RPM Stage 4 Wave track Differential 4:10
-Monster S-Series Triple Disc Clutch
-Monster Standard Weight Billet Flywheel
-Tick Clutch Master Cylinder
-Corsa Extreme 3” Exhaust
-Hooker Blackheart Tri-Y 2” Headers w/ARP bolts
-Hooker Blackheart 3” Race X-pipe
Thanks in advance
