Injectors
Old Mar 13, 2023 | 10:08 PM
Noah alyssa's Avatar
Default Injectors
I was recommended to run the MSD 50# injectors because I am planning on a supercharger set up @ about 7-8psi. I agree also that overkill is good in some areas too but this is new to me. If I run 50#ers and only run up to say 7-8 psi is their any long term ill effects that might come up. Also by going to the larger injectors what in-line fuel pressure do I need to expect to run. I had also learned that some of the aftermarket harness makers ( for LS-1 swaps ) do come with the diagnostic port so I will be able to run the LS-1 edit program! yeeeeeeeaaaaaaaaah!
Old Mar 14, 2023 | 07:28 PM
Old Buzzard's Avatar
"lso by going to the larger injectors what in-line fuel pressure do I need to expect to run".
Start with the pressure the injectors are rated at.
Old Mar 15, 2023 | 09:38 PM
rpturbo's Avatar
With 50# injectors, you'll run out of injector very quickly. 60#'s are probably the smallest I've ever tuned on anything boosted. The stock ECM with even just a decent injector, is capable of controlling a good idle quality with a 60# injector.
People always want more, so I'd say buy a bigger injector, and buy once. JMO
