Weird injector problem
Old Apr 5, 2023 | 07:33 AM
forcd ind's Avatar
Default Weird injector problem
Car has been running great, got a handle on boost problems, starts, idles, drives fine. Idle has always been a little rich, kind of dirties the plugs, never fouled any. I had switched to 210 injectors before tuning, used the drop down to pick them, was a seamless transition from the other injectors. I was pulling the plugs yesterday, #5 looked like it wasn't firing, real clean. I replaced the coil, plug, tested the plug wire, getting great spark, but when I pulled the plug wire no diff in running. I was checking the injector plug and oh $hit, it says #7, senior moment, lol. So I look at #7, says #5, somehow I guess I got them mixed up when replacing the injectors. I ran a comp test on 5 & 7, its inline with the other cyls. Anyway, corrected the wiring, took it for a drive, seems pretty much the same, maybe a hair smoother, but no huge diff. How can it run so good with the 2 inj plugs swapped, not damage the engine. I had made 5-6 boost hits, but only for a couple seconds. I do have Summit forged rods/pistons, pretty sure they could tolerate more than cast. Was it dumping raw fuel out since the injs were prob firing, just the wrong time. I put a fresh set of plugs in last night, going to do some light, med cruising, zeroed the learn, kind of see how the relearn does. (Holley X Max)
Old Apr 5, 2023 | 11:43 AM
sewerpickle's Avatar
It can still run ok in your scenario. Some of the older stuff was bank fire by design. Fired all four injectors on the left, then all of them on the right.
