Holley Dominator boost control
Dome is configured as custom pressure in the I/O and pinned to J2-A1. Solenoids are pinned fill J2-B6 vent J2-B8
I'm going to "guess" and say its a wiring( pinout) issue. It sounds like it's dumping 5v back on the reference circuit which is causing it to show 200psi.
It could be a faulty sensor too.
I did verify the solenoids work by hooking one side to 12v and the other to ground and they do click over. And on the boost vs speed screen in the software the little red bubble is showing where the dome pressure is supposed to be. New sensor is here Monday or possible Sunday so I guess I'll just run it on spring pressure until then
You are obviously in raw dome control id take it
Add target boost(target dome)to your viewing window
If you never show target boost above zero you won’t have solenoid activity
do you have a master enable, what is your target boost at zero mph(if you are in speed)
screen shots of your boost config pages will allow us to sort you out
Any help is greatly appreciated. I'll post up some shots of the software setup
turn the TPS modulation off when you want to test the system.
te target boost and noid activity will be zero unless at zero percent throttle
or hold you throttle wide open or atleast above the modulation setpoint
as was said above, add the target dome pressure to whatever dash or data viewer you are using, if it stays at zero then its a software setting. the tps modulation in this case.
I haven't had a chance to get it out yet as the rain rolled right in but it seems like everything is working as it should. Once the rain stops I'll get it out and take some logs. Thank you guys for all the help it was greatly appreciated
