Oil pressure lines
Old May 9, 2023 | 08:51 PM
vht's Avatar
vht
Default Oil pressure lines
I need a mech gauge and a feed for my turbo, my pan does not have the 2 bolt plate. I was going to use the port behind the intake for 1 and 1 of the ports along the oil rail going along the side of the block going back to the filter. Also I forgot, I have a low oil pressure sensor and light, I need a spot for that sensor. I can T the rear one for 2 of them, would the side of the block work ok for the gauge? Any ideas or opinions welcome.
Old May 9, 2023 | 10:54 PM
Quito195's Avatar
I have oil pressure to my Holley off the factory valley location. I also have oil pressure for my Dakota digital gauges off the port in the block on the drivers side at the front. Both read within a few PSI of each other.
Old May 10, 2023 | 05:23 AM
forcd ind's Avatar
They make a fitting that goes behind the intake, I think like a banjo fitting, you can use it for the factory sensor, and something else. Prob adapt where the sensor goes to something else.
Old May 10, 2023 | 08:38 AM
01CamaroSSTx's Avatar
For the oil feed just drill and tap the pan for an NPT to AN fitting. I have one of the banjo style adapters which allows you to keep the factory sender in place and has a 1/8 NPT to run a 4AN steel braided line from for a mechanical gauge. Works great!
Old May 22, 2023 | 11:06 AM
Donny Wonder's Avatar
Take a look at vibrant performance pressure gauge adapter fitting 16790. I'm using one on my set up.
