No boost
Old Jun 1, 2023 | 10:42 AM
1qwkbrd's Avatar
Default No boost
I have a 5.3 with 88mm fis turbo not building boost. I tracked issue to blow off valve opening. I have found that at idle I have about 13-14 inhg in the intake and as I open throttle vacuum is increased to 19-20 inhg which is causing blow off valve to open. Any idea as to why vacuum would be increasing
Old Jun 1, 2023 | 10:48 AM
TrendSetter's Avatar
you arent opening the throttle enough. at wot you will see zero vacuum.
Old Jun 1, 2023 | 11:44 AM
ddnspider's Avatar
You dont typically want the BOV open at idle or cruise. Run a stiffer BOV spring.
Old Jun 1, 2023 | 12:38 PM
Black_Sunshine_99's Avatar
Stupid question, the reference line is hooked up to the lower fitting below the diaphragm, right?
If its hooked up to the dome fitting then it would open with vacuum, if its hooked to the lower than vacuum should hold it closed and pressure should open it.
Old Jun 4, 2023 | 07:30 AM
1qwkbrd's Avatar
Yes all lines are hooked up as they should be. It was a sudden change. Car was running fine and making boost and then all of a sudden it quit making boost.
Old Jun 4, 2023 | 03:49 PM
Old Buzzard's Avatar
Spring stb?
Old Jun 4, 2023 | 04:04 PM
LSswap's Avatar
Hole in rubber elbows. Had it happen many times. Hard to see the hole when it's not in boost.
Old Jun 4, 2023 | 04:33 PM
1qwkbrd's Avatar
That was my first thought only I smoked the entire cold side of they system. I have had someone tell me check the map sensor. I am running Holley terminator x
 Michael S. Palmer
Old Jun 4, 2023 | 07:57 PM
LSswap's Avatar
I once had the rubber elbow blow off the end of one of the pipes and couldn't see it because it was in a hard to spot location.
Old Jun 4, 2023 | 08:59 PM
GMCGreg's Avatar
Waste gate stuck open ?
Old Jun 23, 2023 | 11:31 AM
sewerpickle's Avatar
Is there still a turbine wheel intact?
