SDCE Spring Tensioner... It works!
Old Jul 27, 2004 | 12:24 PM
IRVINEWS6's Avatar
I received my 8-rib outer crank pulley, but I have'nt received my ATI damper pulley yet. My question is: how does the outer 8-rib attach to the ATI crank pulley? Do you use a longer crank bolt to go through both pulleys? If this is the case, is there a ridge on the ATI crank pulley to keep the two pulleys lined up while you crank down the crank bolt?
Thanks,
James
Old Jul 27, 2004 | 12:44 PM
bomax's Avatar
I think ATI will send you a longer bolt. You turn the crank pulley clockwise until the dowel pins butt up against the dampner then torque down. Use lots of loctite too!
