What crank with procharger?
also, the vast majority of cranks are forged in Chyna including some of callies cranks (non counterweighted) all of the K1, texas speed, etc are not from the US.
I appreciate the diagnosis. Not sensitive, just don’t want to listen to someone else say “go turbo” in a thread that was never started to ask if I should go turbo. I appreciate your input, I truly do, but please stop muddying up my thread with information I didn’t ask for.
Here is a super trick, billet aluminum, front cover with crank support integrated into it. From down under, joe blow speedshop(great name right😁
Shes a beaut.
I have not been on a dyno as I only tune on the street and track. Based upon a 1/8th mile trap speed of 125 mph at 3750 lbs race weight I think it was safe to say I'm over 900 rwhp based upon the calculators I use and that is a much better gauge than a dyno in reality as dynos are much more easily manipulated. It's probably a good bit more than 900 rwhp actually.
My comment was meant to spur discussion on how cubic inches don't have a big impact on peak numbers only the curve as in more torque over a broader range when using the same blower at the same impeller speed as long as there are no major mechanical or ignition issues.
Again, sorry for the misunderstanding and sorry for offending you.
ETA: I'm considering going to an F1x and yes I will continue running the same engine combo until it breaks and then build a new combo.
It's got to be easily over 900 rwhp probably closer to 1000 rwhp with a 125 mph 1/8th mile trap speed at 3750 pounds. I'm on e85 and meth with 18 degrees peak timing with 10.6 to 1 compression and a custom cam motion cam for my combo. IAT with the big air to air are barely over ambient during a pull even in the summer.
paying them for the tune is just their way of collecting profit they have invested into the equipment and wage for employee. If it makes it easier to swallow, call it the cost of using the dyno, but tuner comes free with it.
every shop I’ve used would understand if you wanted to tune yourself though. But the dyno cost is the same.
Their house their rules so I decided to just use trap speed to judge my power level close enough because at the end of the day dyno numbers aren't as important as track times.
It is a beautiful piece and I am sure it will do a great job for what it is intended.
